is there a thread on how to replace a alterntor??? for ls400 92
Old 01-22-11, 12:30 PM
LS400BOY
LS400BOY's Avatar
Default is there a thread on how to replace a alterntor??? for ls400 92
any step by step pics on how to replace alternator on a 92 ls400??
LS400BOY is offline
Old 01-22-11, 01:05 PM
LS400BOY
LS400BOY's Avatar
my alt went out because of acv leaked on my alt and went out, i decided to plug my acv valve then replace my alt at the same time
LS400BOY is offline
Old 01-22-11, 01:34 PM
steve2006
steve2006's Avatar
After a google search I came up with this
http://www.lextreme.com/alternator.html
steve2006 is offline
Old 01-22-11, 02:39 PM
LS400BOY
LS400BOY's Avatar
thanks a mill steve!!!!!!
LS400BOY is offline
Old 01-22-11, 05:39 PM
deanshark
deanshark's Avatar
Pulling the alt isn't too hard. IIRC there is some PS lines ya have to unbolt from the bottom of the oil pan just to give ya more room to get it out. It'll also give you more room to get the ACV off the PS pump. Or, if you're gonna pull the PS pump out to change the ACV then the alt can come out through the top. I've had both of mine out but that was when I did the T-belt, much easier.
deanshark is offline
Old 01-22-11, 09:09 PM
LS400BOY
LS400BOY's Avatar
Im not to take the whole ps out itself just going to unscrew the acv from the bottom, so you saying i got to take off the ps lines to get the alt off??
LS400BOY is offline
Old 01-23-11, 06:09 AM
deanshark
deanshark's Avatar
I'm pretty sure I moved them to get my alt out. There's 2 bolts on a bracket that come out so you can move the lines out of the way. They don't have to be completely disconnected. You'll notice them when ya go to take the alt out. Also, on mine, I unplugged the wires after I got the alt loose and hanging. It's easier then b/c you can spin it and see the wires better.
Old 01-23-11, 07:23 AM
LS400BOY
LS400BOY's Avatar
so the lines are mounted on a bracket??
LS400BOY is offline
Old 01-23-11, 07:56 AM
Bali26
Bali26's Avatar
It will be done from below. Take off serpentine belt. Remove one nut from top. get under car. Remove round plastic wire plug from alternator. Remove hold downs for AC pipes. Remove other bolt from bottom. Twist the whole alternator so that you can unscrew the second wire. Carefully manuver out the alternator. Its a tight squeeze. Kinda like your car having a baby....
https://www.clublexus.com/forums/ls4...lternator.html
Bali26 is offline
Old 01-23-11, 10:15 AM
lowKut
NELOC Moderator
lowKut's Avatar
Question
Mine is shot on my 90 LS.
I've changed the alternator on my 2nd GS 300 which is reletively simple, but the LS seems more difficult to get out as the engine is more compact.
lowKut is offline
Old 01-27-11, 08:27 PM
LS400BOY
LS400BOY's Avatar
How many bolts do i take out 1 or 2??
LS400BOY is offline
Old 01-30-11, 02:43 PM
LS400BOY
LS400BOY's Avatar
I just took it out!! Man was it a pain, you have to take off lower radater hose, fan shroud and battery and battery tray just to take the fan shroud out, then the ald slid out perfect, thanks guys
LS400BOY is offline
Old 01-31-11, 05:30 AM
deanshark
deanshark's Avatar
Damn, you took it out from the top? I never heard of anyone here doing it that way, including me. Figured you would get it from the bottom, seeing how all the answers you received said that. (And it would have been easier) Oh well, it worked for ya. Did you take care of the ACV yet?
Old 01-31-11, 05:37 AM
LS400BOY
LS400BOY's Avatar
I didnt see how yall removed and pulled it from the bottom??? It was way easier from the top for me, yes i removed the acv to now just got to go to the store and get some plugs
LS400BOY is offline
Old 01-31-11, 02:31 PM
Imperium11
Imperium11's Avatar
a question regarding this, if a person is installing a higher output alt say 130 or 145 will we not need to change the fusible link (120a), how hard is that to do?
Imperium11 is offline
Quick Reply: is there a thread on how to replace a alterntor??? for ls400 92
