Severe oil leak/burning oil
Old 12-27-10, 08:31 AM
peaceboi
peaceboi's Avatar
Default Severe oil leak/burning oil
How much would it cost to get the severe oil leak and yes it is also burning the oil, to fix at the shop? It's a 93 Lexus LS400 btw. Helps & answers please
Old 12-27-10, 08:55 AM
Lust4Lexus
Lust4Lexus's Avatar
I'm guessing that the guys here area going to need a little more info, like where is it leaking from? Upper or lower? Other parameters? Last oil change? what kind of oil are you using? You need to give more information to get a better respose. welcome to the club.
NisMax
NisMax's Avatar
Rear main seal? (RMS)
Old 12-27-10, 09:01 AM
andyman32
andyman32's Avatar
Burning a noticeable quantity of oil would be a blown headgasket or piston ring. Is there an external leak as well as burning?
Old 12-27-10, 09:18 AM
peaceboi
peaceboi's Avatar
Originally Posted by andyman32
burning a noticeable quantity of oil would be a blown headgasket or piston ring. Is there an external leak as well as burning?
yes there is
Old 12-27-10, 09:19 AM
peaceboi
peaceboi's Avatar
Last oil change was 4 days ago, still leaking and from lower
Old 12-27-10, 09:36 AM
whiteivory
whiteivory's Avatar
Burning oil will come with a blueish exhaust smoke
Old 12-27-10, 05:00 PM
randal
randal's Avatar
Peace, its going to cost a buck, two ninety-eight to fix. Seriously, as LustForLex pointed out, it is going to take a LOT of info (hopefully not pulled like teeth) to get you any meaningful answers.
You can start analyzing by taking the under-engine cover off, placing a clean sheet of cardboard or newspaper beneath the engine area overnight and letting us know where, precisely on the cardboard, that you notice leakage. If you can locate the general area of the leak and post a picture of the oily engine area, that would help as well.
Old 12-27-10, 07:44 PM
SC300_704
SC300_704's Avatar
from what i know it's leaking from several places since there's a few new oil spots every time it's parked and it is burning oil. from the looks of it i think if we were to take it to a shop to get all the leaks fixed, it will probably gonna cost as much as a good used engine. let's just say the entire head/block is covered in oil, grease, and nasty crap from the previous owner not taking care of it.
Old 12-27-10, 10:13 PM
RA40
Super Moderator
RA40's Avatar
Just not enough info to make any conclusions. How many miles on engine?
Pull the plugs and might as well do a compression check to see how the cyls are doing. If it is high miles, it is worn, you'll be looking at a rebuild. On a '94 unless the rest of the car is good and you deem it worthwhile to keep it going, I'd say EOL.
bdpride04
10-31-17 12:59 PM
Salil022
08-01-12 08:56 AM
rsr2216
RX - 1st Gen (1999-2003)
17
03-20-12 08:38 PM
tritron
Performance & Maintenance
06-29-09 05:33 AM
bguild
GS - 1st Gen (1993-1997)
14
07-19-07 06:29 AM
Quick Reply: Severe oil leak/burning oil
