Doors Freezing, is it typical
Old 12-13-10, 06:15 AM
tomtheslac
tomtheslac's Avatar
Default Doors Freezing, is it typical
Hey guys & gals.
Is it typical for the LS400 doors to freeze shut? I have sprayed silicone lube on all the door seals, but the doors still freeze. Is this typical (for those in the north...), and is there a better solution? (short of a heated garage everywhere you go.. )
TIA.
Old 12-13-10, 06:27 AM
LiCelsior
Retired
LiCelsior's Avatar
yep, happened a few times with the old LS.
Old 12-13-10, 09:11 AM
hobojoe
hobojoe's Avatar
I have had it happen a couple times here, I finally did get it open...Though No solution yet as to a good solid fix. Once It was so cold once I got the door open the latch would hardly move to hold the door closed which was quite a interesting drive to say the least.
Old 12-13-10, 07:33 PM
nervekiler
nervekiler's Avatar
i wonder if a petroleum based lube would have a lower freeze point and help your situation?
i bought my car after it had been sitting for a year and i couldnt get the doors open either! it rains a lot over here and mold had actually sealed the doors shut.
Old 12-13-10, 10:26 PM
mclarenf1k
mclarenf1k's Avatar
Move south.
Old 12-14-10, 06:11 AM
somnoboy
somnoboy's Avatar
Maybe a parrafin-based wax type? I'm thinking along the lines of Pledge furniture wax. Or maybe plain car wax on the rubber seals. Couldn't hurt anything, and might just work.
Old 12-15-10, 06:06 AM
ef9racer
ef9racer's Avatar
wax's are ok but will leave a thick film. wd40 with destroy the rubber after some time. cooking spary like pam works great to help but its still a temp job and can leave a film after a while and will need to be cleaned with soap and water.
Old 01-16-11, 12:01 PM
lowKut
NELOC Moderator
lowKut's Avatar
This just happen to me.
With all the snow we had I haven't drove the car in over 3 weeks.
I occasional remote start it here and there, today after the car shut off I noticed one of the lights were on. I attempted to open the doors which were all shut tight. I did not attempt to apply any pressure and decided to wait until it open on its own. I will have a dead battery if the lights don't shut off on its own.
Old 01-17-11, 08:00 PM
lowKut
NELOC Moderator
lowKut's Avatar
So I finally got my frozen doors to open. Some regular de icer from Auto Zone and manually inserting the key and turn did the trick (note: door lock will not open w/ remote after freezing-up...well it did not work for me).
Old 01-18-11, 05:38 AM
NTRUDA
NTRUDA's Avatar
I used Royal Purple Maxfilm Lubricant around the door seals and I also use a de-icer spray in the locks...works wonders for me.
dlexus1
RX - 1st Gen (1999-2003)
10-23-16 10:23 AM
minielexus
10-08-14 08:34 PM
CameronLax
12-15-10 11:33 AM
lexussc400
SC- 1st Gen (1992-2000)
05-25-04 09:46 PM
Quick Reply: Doors Freezing, is it typical
