Weird issue with heater...96LS...
Hello all. I'm having a slight problem with the heater in my 96LS. It has 192k miles on it and has never given me a single problem. The timing belt and water pump was changer a little over a month ago.
Here is my issue with the car:
I can go out in the morning and crank the car to warm it up. However, even after 15 minutes the car's heater will not be hot. The car will be fully up to temp, but the air is only room temp(60-70). However, when i start driving the car the heater gets hot almost instantly, but when i stop at a stoplight it goes back to room temp, as soon as i pull away...back to hot. It repeats this the entire time the car is running.
I am not getting any error codes and the car is running great.
Any ideas?
Thanks,
Kyle
Any ideas?
Thanks,
Kyle
Mine had this same exact issue - and checked the coolant last night and sure enough I had air bubbles. problem solved, this morning it was nice and toasty after warming up for ten minutes!
winter4w
39
02-07-18 11:04 PM
