94 ecu problem get a junkyard one or send it to get it fixed in tn.
Old 11-21-10, 11:45 PM
dufrain
dufrain's Avatar
Question 94 ecu problem get a junkyard one or send it to get it fixed in tn.
We have a 94 ls with 140000 on it. It recently went into limp mode ,I had to drive it and shift manually 40 miles home. The cel was on with the trac off. I tried to read the codes by using the wire on the port under the hood and the one under the dash. Either place I got no flash on the cel. From what I have found on here it is the ecu not responding, so I went to removing it. I got the dash piece down that it is mounted on.I thought I would try it one more time before I unhooked it and it started ,the cel and trac went out and it started to run ok again. It ran rough for a little since it was loaded up from driving so far in limp mode. It blew gas and carbon out the tailpipes until it cleaned out and started to run ok again. Could it be a bad connection on one of the plugs or connectors.Or could jiggling the computer around getting the dash apart do anything. Im a bit stuck on what to do . If I do replace it what is the best option a junkyard ecu or send it to tennessee to get it fixed.Thax for any help.
Old 11-22-10, 05:21 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
ecu's gone.
so far gone, that i would be hesitant on having it repaired.....hit car-part.com and hunt for one (from a 93-94 only) for cheap.
Old 11-22-10, 05:33 AM
williamb82
williamb82's Avatar
do not use ATE if your going to try and have it repaired. i used them and they are idiots. they "repaired" my ecu twice. still has the same issue. i ended up buying a used one and it solved the issue. then, they wouldnt give me a refund after telling me they would if the junk yard ecu fixed it. even though i have the invoice proving i bought the replacement and can send them the old one. dont waste your money with them.
Old 11-22-10, 01:29 PM
dufrain
dufrain's Avatar
Which one is Ate ,I saw one place is in tN and one is in Fl. I wonder why that thing quit acting up after it got jiggled around.
Old 11-22-10, 01:31 PM
dufrain
dufrain's Avatar
I may just find a used one , I was just worried i might get another one with trouble .
Old 11-23-10, 04:51 AM
williamb82
williamb82's Avatar
iirc ate is in tn. they are called automotive and truck electronics iirc. commonly seen on ebay. the guys dont know squat. they just change some caps and "hope" that fixes it. then when it doesnt, they refuse to give a refund.
Old 11-23-10, 10:15 AM
dawitchdoc
dawitchdoc's Avatar
Hello everyone i'm new to this forum and i hope to get good info on here. I just wanted to chime in on this as well. I had a similar problem with my ecu...no start. I heard about ATE and the crappy work they do and i actually saw some of there work in the salvage yards. While looking for a ecu for another vehicle i came across a ATE repaired unit and i opened it up and saw how bad the work they do really is. Like someone said on here all they do is replace the caps but they do crappy soldering too. I could've soldered better than what i saw...hell my 5 year old could do it alot better with his eyes closed. I went with F.A.C.R. in florida and they got my unit fixed the next day. I found them on ebay through a Mitsubishi listing. I got this done about 6 months ago and no problems at all. I would stay away from salvage yards for these ecu's because eventually they will fail and like most yards no returns on electronic devices. If you want the info let me know and i'll find my paperwork and give you the number or address. Hope this helps in you choice.
Old 11-23-10, 08:45 PM
dufrain
dufrain's Avatar
Yeah post their info I will check them out
Old 11-23-10, 09:54 PM
Bill Dowd
Bill Dowd's Avatar
You can also call 999 lexus used parts in santa ana ca 714-560-1999 all he does is lexus used parts good luck
Old 11-24-10, 09:40 AM
dawitchdoc
dawitchdoc's Avatar
Ok i found it for you. The guys name is Martin and the number is 301-356-6880. The address to send your ecu to is:
F.A.C.R.
Attn: Martin Tate
8102 17TH Ave. West
Bradenton, FL 34209
I think you have to call him first so he can log you in as a incoming rebuild. He will answer any of your questions and get some info from you as well. Check ebay he might have a listing on there with more info. Hope this helps.
If anyone else needs this company i highly recommend them and feel free to use this info.
zion
07-28-16 12:23 PM
rhwimmers
02-25-16 03:24 PM
LShoopty
01-22-16 10:54 AM
Lexstacy40
01-02-09 02:19 PM
3UZTaco
05-04-08 07:00 AM
Quick Reply: 94 ecu problem get a junkyard one or send it to get it fixed in tn.
