Car Cover
Old 11-15-10, 05:42 PM
Scaritto
Scaritto's Avatar
Default Car Cover
I have searched for this, but the results that came in are over 7 years old and do not really contain that good of information.
Does anyone here use a car cover? I want to get one to keep the frost off my car in the morning so i don't have to keep warming up my car. I think it'd be much easier to whip one on and off. Plus, it'd be good for periods where I don't drive it for a while.
If someone can point me to an affordable car cover or the one you use it'd be much appreciated. (Id just needs to get the job done, It doesn't have to be fancy)
Old 11-16-10, 05:37 AM
Bradster
Bradster's Avatar
I've used an outdoor car cover for years here in Fl...If you book out first thing in the morning before the sun has a chance to dry the morning dew from the cover, well it's a big sopping mess to go in the trunk..Also a must is to get a cover custom sized for the LS400 model...generics just do not fit well..
Old 11-16-10, 07:38 AM
MicahBerry
MicahBerry's Avatar
I had one that I used at the airport parking lot. It was a generic, and it did not fit well. On my first trip leaving the cover on the car, the temperature inside the cabin was greatly reduced when I returned in the heat of the day. I was really impressed, even with the poor fit. Unfortunately, when I came back from my second trip, it was gone. Sigh...
Old 11-16-10, 10:44 AM
Bali26
Bali26's Avatar
I've heard its not good for the paint. Constant movement by wind and dirt under it = scrubbing effect.
Old 11-16-10, 11:00 AM
Bradster
Bradster's Avatar
A nice clean waxed vehicle helps and a quality cover usually would have a softer material having contact with the surface of said vehicle..
Old 11-16-10, 01:04 PM
steve2006
steve2006's Avatar
Usual selections here.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old 11-16-10, 02:10 PM
ck90211
ck90211's Avatar
Costco has a decent one (I think around $35) but hard to find an XL for the LS (at least in SoCal). And yes car cover would help if your LS is dark. I have a dark green (95) and a black (96) and both show noticeable fade and peel from California sun.
Old 11-17-10, 06:12 PM
Scaritto
Scaritto's Avatar
We don't get peel from the sun in Ohio Will that $37 ebay one be good you think?
Old 11-18-10, 08:07 AM
Bradster
Bradster's Avatar
Chances are a generic cover would be a little large so it would flop around and fairly quickly the elastic bands will stretch out and some blusterly wind will blow that sucker right off (especially with an inexpensive cover) I used bungee cords to help with that problem...A custom cover made for the LS400 will run $200-400 depending on the quality of the material and usually comes with a 3-7 year pro-rated warranty (which i took advantage of when the seams started to split)
loophole35
03-01-19 12:27 AM
gebo
Automotive Care & Detailing
08-06-15 11:30 PM
Quick Reply: Car Cover
