Upper ball joint spec
Old 11-12-10, 12:45 PM
tomtheslac
tomtheslac's Avatar
Default Upper ball joint spec
I have failed safety twice now because of upper front ball joints. Replaced them from a donor and still failed. I have the service manual and it gives 9 to 30 in/lbs for tourque spec on the ball joint. The ones I put in passed that test. My mechanic however just puts a pry bar on the coil and lifts the UCA. How much play up/down play is acceptable? Is there supposed to be some wiggle room or do I really need new ones?
Thanks in advance...
Old 11-12-10, 02:19 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
find a new mechanic, that's such a ghetto way to rig a safety test....
if you put the wheel on and there's no noticeable play, it's safe enough to pass most state-mandated inspections.
Old 11-12-10, 03:05 PM
tomtheslac
tomtheslac's Avatar
Ordered the Arnott's anyway...now I have two sets of UCA's to see if I can remanufacture one. OEM set with another balljoint
Old 11-12-10, 05:07 PM
PureDrifter
BahHumBug
i wouldnt run arnott, esp. with all the recent experiences members have had.
Old 11-13-10, 03:20 PM
StevieA
StevieA's Avatar
I got APXautoparts $130/side Ebay installed them last week nice & smooth now both my old ones were loose & knocking over gravel/rough bumps obvious up & down play with a pry bar & wheel off
Old 11-14-10, 06:27 AM
tomtheslac
tomtheslac's Avatar
I am going to take these into the shop (too&die) and see if I can re/re one of these with a $20 balljoint from Napa. Just to see...
Old 11-15-10, 02:44 AM
Max Power
Registered User
Max Power's Avatar
Stevie, How are those APX ones? No problems with the install?
Old 11-15-10, 09:11 AM
StevieA
StevieA's Avatar
Not at all. I remember you and JimsGX saying the Arnott ones had the wrong taper on the ball joint so I was weary of that when I installed these but everything fit great.
When comparing to those I removed from the car, the old ones where thicker steel on the opposite ends from the ball joint (I'm assuming the ones I removed were OEM) but that's about it. Time will tell if the boot on the ball joint stands the test of time.
Old 11-15-10, 07:44 PM
Max Power
Registered User
Max Power's Avatar
Awesome!! that's good to know!!!
Old 11-16-10, 12:19 AM
Max Power
Registered User
Max Power's Avatar
Actually, I wanted to ask if the cotter pin hole lined up directly with the castle nut?
Old 11-16-10, 08:32 AM
StevieA
StevieA's Avatar
The thread of the ball joint bolt offered several holes to choose from for the cotter pin so it was an easy fit!
Old 01-23-11, 06:38 PM
KevinE.
KevinE.'s Avatar
how are the APX UCAs holding up?
Old 01-23-11, 07:13 PM
StevieA
StevieA's Avatar
Haven't done a visual inspection but working fine. Will have it on the hoist soon will post if any problems
GSdarksol
Suspension and Brakes
05-15-17 09:16 AM
Vadim540i
09-26-14 12:32 PM
qwerty04
12
01-24-13 03:31 PM
1lexus2c
05-24-11 01:43 PM
datsetup
01-12-07 11:20 AM
Quick Reply: Upper ball joint spec
