harmonic shudder/vibration at idol
Old 11-12-10, 08:44 AM
atoyot
atoyot's Avatar
Default harmonic shudder/vibration at idol
any idea where to start looking for the cause of this?
Basically it's just started about 2-3 months ago. When i start the car i get a vibration almost like a shudder around 1,000 rpm when the car idols. Give it gas and it goes away. It's not bad, but it never happened before. It's not a constant vibration, it oscillates every couple of seconds.
The best way i can describe it is if one of the pulley's is slightly loose and has a little vibration as it spins. That's probably the first place i will check. Second place i will check is a belt to see if it's cracked or if there is a problem.
Thought i would ask if anyone has experienced this before?
Old 11-12-10, 10:56 AM
williamb82
williamb82's Avatar
sounds like a slight miss. id check the plugs, and also run a can of seafoam in the gastank to make sure the injectors are clean. any engine codes?
Old 11-12-10, 11:54 AM
GillaG
GillaG's Avatar
Check your trans mount also. Mine was idling smooth until I got up to 1000 RPM and above and then the quick vibration came through the car. I replaced the mount and it was split in half, now the vibration is gone. Just have a vibration in gear at idle even after I neutralized the transmount but I think it is because of a faulty TP sensor or air bypass valve.
Old 11-14-10, 06:03 AM
atoyot
atoyot's Avatar
thanks for the replies.
No engine codes.
I will check the plug wires to make sure they are secure.
A little more information, it's not a really bad shudder, it's just enough for me to feel through the seat and steering wheel. Doesn't make any strange noises.
Old 11-20-10, 01:35 AM
skperformance
skperformance's Avatar
sounds like the clutch for the fan is locked up . If its making alot more noise like a turbine when revved when the car is still cold , that's the problem.
LXotic
Maintenance
12-23-12 08:43 PM
85Krtagena
09-23-12 06:29 PM
al-ex-us
Performance
06-20-09 09:54 PM
BIPPUthis!
GS - 1st Gen (1993-1997)
12-29-06 11:22 AM
skoles
Performance & Maintenance
11-16-06 03:59 PM
Quick Reply: harmonic shudder/vibration at idol
