1998 LS400 spungy brakes
Old 10-29-10, 02:49 AM
fastegg
fastegg's Avatar
Default 1998 LS400 spungy brakes
The brakes work fine but the pedal feels like pushing a spunge...... any surgestions ?
Old 10-29-10, 06:11 AM
deanshark
deanshark's Avatar
You have air in the system somewhere that needs to be bled out. Did you do any brake work recently in which you removed any hoses or anything? Is it a problem that just popped up or has it been progressively getting worse?
Old 10-30-10, 08:28 AM
3UZFTE
3UZFTE's Avatar
+1 for bleeding the brakes.
Old 11-15-10, 08:00 PM
tonyfazt
tonyfazt's Avatar
bleed the brakes if the problem persist
time for a new master cylinder
Old 11-15-10, 08:21 PM
RA40
Super Moderator
RA40's Avatar
+2 on bleeding
May also be a stuck piston.
Old 11-15-10, 09:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
x 1bajillion for bleeding the brakes.
Old 11-18-10, 12:13 PM
nthach
nthach's Avatar
How do your brake lines look?
Old 11-18-10, 04:52 PM
Vincent123
Vincent123's Avatar
is it worth it to go stainless steel brake lines or just bleed them? Mine are spongy as well
Old 11-18-10, 05:55 PM
PureDrifter
BahHumBug
visually check the lines, if they're old and getting hard, or starting to balloon, SS lines are a good replacement for stock as long as you get good quality lines.
do the bleed first though, as it will let you know if the lines really need it, and flush all the crap out so that if you do swap lines, you wont get gunk stuck in your new lines.
Old 11-20-10, 01:27 AM
skperformance
skperformance's Avatar
start by
bleeding brakes
servicing calipers properly by lubing ( if not replacing ) all seals and wire wheeling sliders
look at the brake booster , if you press the pedal once and it is soft , if you press it again is it slightly stiffer and keep stiffening up the pedal with each depression ?
If so the booster has a leak .
64convert
04-24-08 12:13 AM
Lexs400
Maintenance
07-08-05 02:35 PM
Lexs400
07-08-05 02:29 PM
TRiis2004
SC- 1st Gen (1992-2000)
01-13-02 04:22 PM
clivej
08-20-01 12:05 PM
Quick Reply: 1998 LS400 spungy brakes
