ECU reset question for LS430??
Old 07-24-02, 02:14 PM
mrpogi
mrpogi's Avatar
Default ECU reset question for LS430??
I'm trying to reset the ECU for my 2002 LS430 because the acceleration delay is more than whats acceptable to me. My question is which fuse do i need to remove and reinstall. I don't see any fuse with ECU label. Is there any other label for that ECU fuse?
Old 07-24-02, 08:13 PM
Leeladisky
Leeladisky's Avatar
Default ECU Reset
Look for fuses labelled EFI or Ignition
L
Old 07-24-02, 09:21 PM
ShowGSLuVv
ShowGSLuVv's Avatar
or better yet just disconnect the NEGATIVE battery and keep ur car in ETC mode or whatever it's called, that's pretty much the most u can do to help with the downshifting
ShOwGS
Old 07-25-02, 09:33 AM
ChrisK
ChrisK's Avatar
The fuse could be labeled EFI or ECU+B.
Old 07-25-02, 03:41 PM
Phu
Phu's Avatar
Does anyone know if disconnecting the battery will erase your navigation system settings?
Old 07-27-02, 06:27 PM
VVT-i
VVT-i's Avatar
No. All of your setting will be the same and all of your previous destinations will be the same.
wayman28
09-23-14 07:48 PM
lillexrx
RX - 1st Gen (1999-2003)
12-05-09 06:08 PM
ns3425
03-13-08 07:42 PM
black sc
SC- 1st Gen (1992-2000)
12
05-16-05 12:17 PM
Intellexual
11-02-04 01:22 AM
Quick Reply: ECU reset question for LS430??
