Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
What type of oil do you use? (The Mother thread)
Thread Tools Search this Thread Display Modes
Old 03-10-03, 12:21 AM   #31
elclassico
Trader Score: (0)
elclassico's Avatar
Post any oil recomendations for LS400?
150, 000 miles, LS 400 1990. time to change the oil. the car consumes some oil, not much. i was wondering if any one could recomend a blend? probably something thicker then recomended in the manual? i heard no synthetic oil for higher milage cars, but synthetic blend ok? any brands or oil types anyone can suggest. thanx!
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
"There is none who cannot teach somebody something, and there is none so excellent that he canot be excelled." -B.G.
elclassico is offline   Reply With Quote
Old 03-10-03, 11:57 AM   #32
rybikowsky
Trader Score: (0)
Mobil 1.
rybikowsky is offline   Reply With Quote
Old 03-15-03, 12:53 PM   #33
Pilot
Trader Score: (0)
I would run standard oil with one quart of Marvel Mystery oil for 1000 miles. Then change oil and filter and run Mobil 1. The Marvel Mystery oil will clean the rings and help them seal better. It will also mildly clean the entire engine very gently. I did this to mine and now run Mobil 1.
Pilot
91 LS400
01 RX300
Pilot is offline   Reply With Quote
Old 03-15-03, 02:27 PM   #34
LexFather
Guest
Trader Score: ()
Posts: n/a
Well, no engine problems in either SC 400 or ES 300 with over 200k miles and no engine problems in the GS with 100k miles.
I am a firm believer in Castrol. I add stuff like Mystery oil and oil additives from time to time as well as a Synthetic oil change every now and then.
Old 03-15-03, 04:59 PM   #35
elclassico
Trader Score: (0)
elclassico's Avatar
Post the verdict is in...
higher mile cars do need extra love. you cant use what it says in th o/m. especially this ls consumes some oil...so thicker is better. its also known that synthetic isnt good for higher mile cars so...i went with a synthetic blend by castrol sae 20w-50. partly synthetic. i would recomend the same in a similar situation. ran much smoother and thicker so it consumes less. thanx to all who responded!
__________________
Old 03-15-03, 05:01 PM   #36
1994 LS400
Trader Score: (0)
Hello ~
My 1994 LS now has 111,000 on the clock, well back @ 104,000 I switched her to Mobil 1. All was GREAT till 109,000. I got home from vacation and the car sitting for 2 1/2 weeks, and found Mobil 1 oil ALL OVER the garage floor (Rear Main Seal). Now I am not able to blame the Mobil 1 100% as the car is 9 years old, and seals do wear, however I am now very weary of Mobil 1 in older engines. Most people are A OK with Mobil 1 and have not had any problems, guess I was one of the lucky few . I am currently using Valvoline MaxLife 5W-30 (blend) on my way back to Penzoil reg dino oil 5W-30.
Best Of Luck.
Paul
__________________
Proud LS400 owner
1994 LS400 is offline   Reply With Quote
Old 03-15-03, 07:47 PM   #37
spxChrome
Trader Score: (0)
spxChrome's Avatar
Send a message via ICQ to spxChrome
my lex dealer uses castrol no synthetic and they claim to be servicing lexus with over 400K... most people here suggest mobil 1. but my car isn't fake so i don't put fake oil in it
but what do i know
__________________
2006 LS 430 & 2004 RX 330
retired: 1999 ES 300, 1993 LS 400
spxChrome is offline   Reply With Quote
Old 06-27-03, 08:44 PM   #38
RA40
Trader Score: (6)
RA40's Avatar
Default Strut cartridge recco's
Howdy, this is my first post here.
Our '97 LS has a tick under 70K miles and I'm going to have some Eibach Pro Kit springs put in. While it is apart for this, I wanted to have new strut cartridges installed. I really like the Tokico HP's but I haven't seen them for this application. What struts would you recco to be close to these?
Thanks.
MF
'97 Coach ed
__________________
Mike
RA40 is offline   Reply With Quote
Old 06-29-03, 08:03 PM   #39
jbatast
Trader Score: (0)
I also have a 97 LS with 65K. The T. Blues are not made for the 1997 as far as I know, that leaves the KYB-2, TEIN TYPE CS DAMPER KIT and Bilstiens. I think I am going to go with the KYB-G2.
Did you have the following problem.The car makes a “clunk” when I travel over certain bumps. For example, if I make a left hand turn across the road into a parking lot that has a raised concrete lip of an inch or two, the suspension makes a clunk (as if it bottoms out) when it hits the lip. This happens regardless if I am on the brake or not. Also, if I travel on a bumpy road, the car handles ok, but if I travel the same bumpy road and apply the brakes, it make the clunk noise over the bumps. I tend to loose some control in the steering that is the steering feels loose. I am convinced it is not brake problem related.
Lexus and two other mechanics all hear the problem but cannot determine what it is. They say everything looks tight. They do not think it is the struts. Neither do I. I think it is a bushing problem on one of the bars (strut, sway, upper/lower control arm… I don’t know and everyone uses different names for the same bars…it would be nice to know what the correct names are?). Good luck
jbatast is offline   Reply With Quote
Old 06-30-03, 01:33 PM   #40
RA40
Trader Score: (6)
RA40's Avatar
Toysport suggested that a stock type replacement will be fine with the Eibach Pro Kit. They could order a JDM cartridge but at ~$200 some odd each , I'd be shy from the Tein coil overs by the time I'm done. I'm leaning toward the Bilsteins.
Has anyone been adventurous and tried fitting any of the more generic GS parts on the LS? Those guys have oodles of goodies. If the GS400 cartridges measure out the same I don't see why not. What does that car weigh and if it is stiffer, it should balance out me thinks. <shrug>
Yes and from the left front on severe road disturbances, like 2-3" deep pot holes. When I did an oil change, I tried wiggling what I could under there and couldn't find it. I suspect a hidden thing like: strut cartridge, strut hat or wheel bearing.
On a past car at 165K miles, it was a tie rod that had worn. From my limited experience, I had removed a cartridge that had a dead spot for whatever reason. Felt almost fine when compressed but at a certain point, it had little to no resistance. Didn't make sense to me.
I hope to do the springs and struts in a few weeks if all goes well.
__________________
Mike
Old 09-27-03, 02:44 PM   #41
jbatast
Trader Score: (0)
Need an answer to this question
Old 09-27-03, 10:07 PM   #42
RA40
Trader Score: (6)
RA40's Avatar
This interests me as I intend to install Eibach wiith Bilsteins. As I recall, BiIsteins are HD and probably a OEM spec type. <shrug> May be similar in feel to the KYB GR2 which are also OEM type replacements.
__________________
Mike
Old 09-28-03, 10:53 PM   #43
SilverFlare
Trader Score: (0)
SilverFlare's Avatar
Send a message via Yahoo to SilverFlare
my LS hv bilstien & lsportline setup and the ride is almost same as the stock even with 19" rimz,
I highly recommend this set up to u, it won't scarfice the comfort of ur LS.
__________________
Silver/Black --- 2006 -- GS430
*Ings hybrid kit*80k HID D4S & 9006*LMS intake*HKS filter & HKS exhaust* Junction Prouce Scara*Juzu**Eibach*Artisan front grill*Artisan Roof spoiler*Artisan spoiler*Artisan mirror blinker*
White/Black --- 2008 -- TT 3.2 (Stock)
SilverFlare is offline   Reply With Quote
Old 09-29-03, 01:17 AM   #44
RA40
Trader Score: (6)
RA40's Avatar
How does the car corner with this suspension? If you were to give it a percentage over stock.
__________________
Mike
Old 09-29-03, 01:17 PM   #45
Lexkost
Trader Score: (0)
Lexkost's Avatar
Default Re: LS400- LSportline & Bilstein
Quote:
Originally posted by JohnnyBlaze
What does everyone think about Bilstein shocks on the LS400?
I know LSportline offers a package with bilsteins and Eibach springs. But will the car lose much of it's supple ride with this application? Anyone have bilsteins on a LS400?
I have the bilsteins and eibach(not the lsportline) I run the front set-up on the lower strut setting and the back on the higher strut setting and I like the ride..............handling is great and the ride is complete different........
__________________
96 Green LS
Lexkost is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Facts about oil and what grade to choose RgSc Performance & Maintenance 29 02-21-15 10:23 AM
Engine oil/ tranny oil Volume123 Performance & Maintenance 5 05-04-13 08:16 AM
General Maintenance SharpSpurs GX - Second Generation 22 03-02-12 10:05 AM
Valvoline Synthetic or Mobil1 Synthetic? hoonami ES300 and ES330 21 02-20-09 01:03 PM
A lesson on oil jagtoes ES350 (2007 - 2012) 7 12-17-08 09:41 AM
Tags
125k, 180000, 1990, 1992, 1994, 1995, 1st, 2002, 2005, 20w50, 250, 277000, 30, 300, 3ook, 400, 5w, 5w30, 70k, 92, 94, 99, amsoil, beta, bilstein, bilsteins, bmw, brand, burning, buy, cam, cars, cartridge, castrol, change, club, cooling, crank, dealer, differences, dino, driving, edge, eibach, engine, es350, filter, fluid, flush, full, gallon, gen, good, grade, grage, high, is300, j1858, kind, lasts, leak, lexus, logo, long, ls, ls400, ls430, lsportline, lub, main, mileage, miles, mobil, mobil1, mobile, motor, negatives, oil, ow, pennzoil, penz, penzoil, platinum, put, putting, quarts, ratio, rear, recomendation, recommendation, reviews, run, rx330, ryco, sae, sc400, sc430, seal, seals, seeping, sl, slander, soarer, specs, start, straight, strut, struts, summer, switching, synthetic, sythetic, take, tein, test, trans, transmission, type, valvoline, viscosity, walmart, weight, year, zddp
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
