'95 LS dies ONLY when getting off freeway ONLY when below ~55* ambient
Old 10-12-10, 06:42 AM
I'mStock
I'mStock's Avatar
Default '95 LS dies ONLY when getting off freeway ONLY when below ~55* ambient
Car never gives me trouble except on cold mornings when I'm getting off the freeway after my ~60 mile commute, when it's 55* or below. It'll die once I exit unless I maintain the revs myself. No other issues ever, car runs and drives like it should the whole way, it's just when my speed decreases... Once I start the car again, it runs great, like nothing ever happened.
Anything?
Old 10-12-10, 06:43 AM
I'mStock
I'mStock's Avatar
Morning commas strike again.
Old 10-12-10, 07:18 AM
python
python's Avatar
think this has occured to other members...try doing a search, might be a computer problem.
Old 10-12-10, 10:57 AM
I'mStock
I'mStock's Avatar
I did search but it didn't really seem like any of the others were having problems in cold weather.
Old 10-12-10, 12:34 PM
Marklouis
Marklouis's Avatar
does seem to be the behavior of a bad ECU - it will do this no matter the temperature - it may be happenstance that it just started this in the change of seasons - did it behave like this last fall/winter?
Old 10-12-10, 02:43 PM
I'mStock
I'mStock's Avatar
Yes'sir.
Old 10-13-10, 06:19 AM
Marklouis
Marklouis's Avatar
mine behaves like this after long drives - I can pull off the freeway after driving 80 mph for 3 hours and it idles so low it does die at times, but it will not do this in regular daily driving. it also will have the "hiccup" at times when letting off the gas pedal - both signs of a faulty ECU, it only acts up about 30% of the time. bad thing is these cant be reprogrammed for the fact they use Flash memory tech, so you have to find a "repaired" unit or a unit with a specific model # that doesnt have the issue. there are several links to find a ECU replacement if you use the search option - I will be replacing mine soon enough because it seems to be getting worse.
Old 10-13-10, 07:31 AM
3UZFTE
3UZFTE's Avatar
I doubt it's the ECU, check for vacuum leaks or any possible signs or an un-metered leaked after the throttle body... Just my 2 cents.
Old 10-13-10, 02:46 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
given the TSB for 95-96 ECUs doing just this, i would say it's a fair possibility.
search this forum for "ecu*" without the quotes and you'll see other member's results.
t2d2
Performance & Maintenance
24
10-06-21 07:39 AM
RxG300
18
07-30-12 04:37 AM
Nikolaos
SC- 1st Gen (1992-2000)
41
12-09-10 05:22 AM
bigjrocc
07-24-08 09:38 PM
chubby
12
02-10-07 09:23 AM
Quick Reply: '95 LS dies ONLY when getting off freeway ONLY when below ~55* ambient
