1st generation with 2nd generation intake
Old 07-22-02, 03:49 PM
healerhand
healerhand's Avatar
Default 1st generation with 2nd generation intake
Anyone know if 1st generation LS400 with 2nd generation upper intake would work?
Old 07-22-02, 03:55 PM
LOTC
VIP 様式
LOTC's Avatar
I believe it will not, the angle on the 2nd gen is more at a 90 degree angle then the 1st gen
Old 07-22-02, 05:37 PM
healerhand
healerhand's Avatar
1st gen is 90 degrees to the right and 2nd gen i straight to the front or zero degree. If the bolts pattern is same, then it should fit. If it does fit. Placing a Top Mount Intercooler is much easier.
david
Old 07-22-02, 10:22 PM
JBrady
JBrady's Avatar
David,
I presume you mean the entire intake manifold both the upper and lower parts? Also, by 2nd gen I assume you mean the 98 and newer engine parts for the VVTi engine. The 90-94 cars are considered 1st gen. 95-97 2nd gen. The intake manifold for both 1st and 2nd gen cars look the same. 98-2000 cars have the front located throttle body that you speak of. This manifold has a variable plenum chamber so that function would probably be lost with a retrofit. 2001 and newer LS4xx are 4th (also 4.3 liter displacement).
I just bought a 98 LS400. It is back at the dealer getting a proper wheel alignment. I will try to get an response from one of the technicians on this possible swap. I will also pull the engine cover to give my own impressions.
Old 03-09-04, 10:43 AM
Jasoneo5
Jasoneo5's Avatar
Will a the engine cover that can be found on a second generation LS fit on a 1st Gen?
I would want it just for looks
-Jason
johnhol123
GS - 1st Gen (1993-1997)
02-04-24 08:13 AM
gmeardi
International
08-04-22 06:12 AM
jonrago
01-28-07 02:23 PM
Quick Reply: 1st generation with 2nd generation intake
