have problem when i lower my car need help
Old 09-28-10, 08:33 PM
nutty13
nutty13's Avatar
Default have problem when i lower my car need help
hello all ls400 guy
I have 99 ls400 then i go lower my car with coil Algernal suspension also i'm on F 19-10+24 R 19-11+6 and i'm don't have picture for my yet. Then ABS,VSC light show up on my dashboard.What can i do to fix that please let me know
thanks Paul
ps.More problem how many of you have a clunking noise problem after a coilover set is installed?
Old 09-29-10, 12:04 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
you most likely tore one of the ABS wheel sensor cables.
or you're low enough that you jacked up the harness in one of the front wheel wells.
Old 09-29-10, 08:36 AM
whiteivory
whiteivory's Avatar
LoL
happened to me last week.
TSC and ABS light is on, no temperature reading, and key won't start engine (Now have a bypass)
Old 09-30-10, 03:44 PM
nutty13
nutty13's Avatar
I'm already check on my ABS sensor look like not thing wrong with that so what should i do now?(do i have to make a bypass right whiteivory say) let me know guy.
thanks
ps. car still run good noting wrong. Just ABS,VSC light show up
Old 09-30-10, 11:42 PM
silos5
silos5's Avatar
Hello,
I have a similar problem, I´m on bags and I drive slammed.
ABS light never came on, but the pedal shakes sometimes
VSC warning light comes sometimes when I play with the switches or turn the wheels to end when I turn. I went to one shop and was told that the car computer can somehow understand that I´m low and that my wheels are not stock.
But yes, this doesnt give me any problem, I have checked all the wires and everything seems OK, so I dont really pay any attention now.
Old 10-10-10, 01:08 PM
nutty13
nutty13's Avatar
Old 10-10-10, 01:10 PM
nutty13
nutty13's Avatar
hello all ls400 guy
thanks Paul
Old 10-10-10, 01:21 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
The clunking noise could be the suspension bottoming out. Did you buy the coilovers new or used? Did you adjust the coilovers using the bottom strut perch?
Old 10-10-10, 02:46 PM
nutty13
nutty13's Avatar
i don't know but i bought used coilovers from japan.then what can i do now
ps. my coilovers is algernon.
Old 10-10-10, 06:57 PM
RA40
Super Moderator
RA40's Avatar
You may now have the caster/strut bars in a new position that the bushing does not like. As in the bushing is torn and now that it is stressed differently, it is clunking. Aside from the other advise, raise it up a bit and see if the noise persists.
Old 10-11-10, 12:55 AM
j three
j three's Avatar
That could be the control arms hitting the top of the wheel well, as I have a feeling you are super low. Post some pics so we can see your ride. Also double check your front left fender well above your tire to see if the wire harness is chewed up. If so you need to get on it and do a re-location and repair the wires asap because it will only get worse.
Old 03-18-12, 09:53 AM
Kaiyin
Kaiyin's Avatar
has anyone relocated the harness, and if so where? I checked mine last night and I've worn through the black tubing so that you can see the wires (haven't worn through any of the wires yet).
Old 03-18-12, 12:07 PM
PureDrifter
BahHumBug
the "right" way to do it involves disassembling the main fusebox and removing the driver's side fender to reroute.
personally i've pushed mine as high up as i could and i still rub on it sometimes, at some point i'll have to go through that massive pain and strip the whole front end to reroute it.
Omarls400
06-29-18 06:16 AM
LS460ROCKS
08-04-17 08:26 AM
vmotors
01-17-10 09:39 AM
undee
05-05-08 05:36 PM
eyecon7
02-24-06 11:26 AM
Quick Reply: have problem when i lower my car need help
