Coolant overflow resevoir/coolant level sensor swap
Old 09-18-10, 10:55 AM
ucf10nate
ucf10nate's Avatar
Default Coolant overflow resevoir/coolant level sensor swap
Has anyone done this? My 1990 LS has an irretrievable broken coolant level sensor lodged somewhere in the coolant overflow reservoir. I'm planning on pulling the reservoir+sensor from a 1993 LS but I have a few questions:
1) What should I pull before pulling the tank/sensor?
2) Does anyone know if the sensor from 1993's is compatible with 1990's? I'm not too worried about the tank fitting because there will probably be a way.
Old 09-18-10, 11:11 AM
python
python's Avatar
u never followed up on the water pump not working post....do u really think people are going to want to help when they take time out of their day to give advice and u never respond, then make another post asking help again?! good luck with that...let me know how that works out for u
Old 09-19-10, 02:18 PM
ucf10nate
ucf10nate's Avatar
i've never had a problem with the water pump.
Yeah I was kinda hoping that if I had questions about a car I just bought that I could just post some questions on a forum and get them answered. Thanks for your help though!
Old 09-19-10, 02:56 PM
Raddison
Raddison's Avatar
As far as I know they should be the same
Old 09-20-10, 04:20 PM
damon
damon's Avatar
I am fairly sure this is going to be a common Toyota part. (anyone have a #?)
Mine is starting to go & currently emits an intermittent false signal. 94 LS
Old 09-20-10, 04:42 PM
Kansas
Kansas's Avatar
Don't think they are all the same. For example, the part number database I use shows the "switch assembly, level warning" is part number 85335-50010 for the 90 LS400 and part number 16485-50012 for the 94 LS400.
Old 09-21-10, 04:20 AM
StevieA
StevieA's Avatar
Bought my '93 LS in March 2010 with the light constantly illuminated. Took it to Toyota for their opinion and they snipped the wires. That fixed the light
Oh well its just a level sensor on an older car I can live without it
Old 09-21-10, 08:40 AM
python
python's Avatar
lol my bad nate....
Old 05-10-13, 10:26 AM
Ruddigore2
Ruddigore2's Avatar
Level sensor should be same up at least to 1995 LS 400s.
Rob Jay
afpj
RX - 3rd Gen (2010-2015)
02-24-18 10:43 PM
LeftSideES
03-27-16 12:35 PM
DanielDD
Performance & Maintenance
12-04-14 03:55 PM
wirelesstj
11-17-11 11:03 AM
tenchu
07-05-11 05:03 PM
Quick Reply: Coolant overflow resevoir/coolant level sensor swap
