19 inch tire question
Old 09-17-10, 02:24 PM
samurai469
samurai469's Avatar
Default 19 inch tire question
was running 245-40-19 front and 275-35-19 in rear,
got poor so ran 225-40-19 in front and one blew out.
will a 235-45-19 fit in the front???
i am running 5-zigen gravis wheels 9.5 offset unknown on 2000 ls400 with tanabe springs.
Old 09-20-10, 11:51 PM
samurai469
samurai469's Avatar
ok update,
used tire shop did not have 240 40 19, so i got
255-40-19 nitto's
had to take off the mud guard cover to reduce rubbing, and took off my 10mm spacer.l
running 5 zigen gravis 9.5 offset 38 in front.
only rubs a little now during hard cornering, hitting fender.
i am running old tanabe springs, rears are really really really tucked.
anyone have stock springs they want to let go?
or debating for eibachs.
thanks.
Old 09-21-10, 07:36 AM
4DGS
4DGS's Avatar
I'll take your tanabes
BTW, you might be having traction control issues and your speedometer WILL be off with the fronts being so wide. If you were to move up to a 255 tread I would drop the profile down to 35.
Old 09-21-10, 01:36 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
255/40-19 is closer to the factory diameter than 255/35-19 is, no problem there.
it will rub without a proper roll.
MethodRN
07-11-16 12:11 PM
5nX37
07-03-15 09:13 AM
MrBBQ
05-30-09 12:37 AM
SweetS160
02-03-08 12:44 PM
Silver GS
Wheels, Tires & Brakes Forum
01-19-07 05:17 PM
Quick Reply: 19 inch tire question
