97 ls strut bars or bushings
Old 09-13-10, 05:47 PM
flyboeing1
flyboeing1's Avatar
Default 97 ls strut bars or bushings
ar needs strut bar bushings. Any imput on which i should replace, complete bar or just the bushings. Bars i found for about 100 each and bushings about half that. Anything i should know?? Thanks in advance
Old 09-13-10, 06:16 PM
RA40
Super Moderator
RA40's Avatar
Some can remove the bushings easily but IMO, a R&R of the whole assembly is faster. In the end, labor cost relative to part cost nearly becomes a wash.
Old 09-14-10, 04:05 PM
billydpowe
billydpowe's Avatar
on my old 97, I replaced them with Polyurethane bushings, pressed out and in, no problem. I also have a set for my 99, when it needs them... (no labor cost involved)
Old 09-15-10, 06:32 AM
acidfire52
acidfire52's Avatar
I tried to do that on my '97 last weekend. Did not work like I wanted. Could not get the old ones out. So, I went and bought new arms. Very easy that way if a bit expensive.
Old 09-15-10, 02:46 PM
flyboeing1
flyboeing1's Avatar
what stopped you from just replacing the bushings. Was it tooling ???
Old 09-15-10, 06:19 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you need a press to push the old bushings out.
Old 09-16-10, 07:57 AM
acidfire52
acidfire52's Avatar
I was not able to get the old bushing sleeve out. You need some sort of hydraulic press to get it out.
Old 09-16-10, 11:26 PM
PureDrifter
BahHumBug
i had a local shop do that part for me, cost me about $15-20 for both arms.
Old 09-17-10, 02:56 AM
billydpowe
billydpowe's Avatar
I have a press available (business friend) and knowledge of necessary safety. It takes a good bit of pressure to get them to move.
BigBang
Suspension and Brakes
09-21-13 11:23 PM
mdpuff
08-09-12 12:10 PM
billydpowe
37
09-25-10 01:47 PM
mark98ls40
07-19-10 09:30 AM
hyperopt
01-06-06 06:35 PM
Quick Reply: 97 ls strut bars or bushings
