should i buy these spacers?
Old 09-09-10, 04:14 PM
2000 ls400
2000 ls400's Avatar
Default should i buy these spacers?
i am putting on sc430 wheels with 245 45 18's these spacers seem like a good deal. http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 09-09-10, 06:53 PM
BLKonBLK98
BLKonBLK98's Avatar
don't look to be hub centric. i'd pass.
Old 09-09-10, 09:26 PM
Kyoei
Kyoei's Avatar
I would not buy if its not hub centric.... you get what you paid for....
Old 09-09-10, 09:53 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
H&R 5x114.3 15mm bolt-on adapters.
Old 09-10-10, 03:21 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
What PD said. Those Ebay ones are 10mm too thick.
Old 09-10-10, 09:47 AM
2000 ls400
2000 ls400's Avatar
if i got 25mm would they rub?
Old 09-10-10, 04:29 PM
BigLexx
BigLexx's Avatar
excuse my ignorance guys, but what is hub centric? And why is it important to use em?
Old 09-10-10, 06:01 PM
JimsGX
JimsGX's Avatar
The center hub wheel diameter for "most" Lexus vehicles is 60.1mm... This is the opening in the center of your rim that mates to your rotor / hub... On many aftermarket wheels (and spacers in this case), in order to make them useable on a wide variety of vehicles, the center hub on the rim is larger and a plastic centering ring adapter is used to compensate for the different sizes of hubs used on all vehicles. In my experience, these adapters can cause wheel vibrations and I avoid them. The spacer they're talking about here, doesn't have a 60.1mm opening in the center of it so that it will match up perfectly to the hub on the vehicle. It's dependent solely on the perfect alignment and spacing of the studs, which is much less precise.
Here's a link to a Lexus bolt pattern guide that also discusses center hub sizes and offset's... http://www.vehicle-bolt-pattern.com/...nce-guide.html
Leechmon
04-29-18 11:38 PM
JamesG
07-08-13 04:04 PM
gs3some
09-13-12 04:55 PM
joeker
Wheels, Tires & Brakes Forum
06-22-10 05:47 PM
supralative
SC- 1st Gen (1992-2000)
13
03-13-09 01:55 PM
Quick Reply: should i buy these spacers?
