Wont start 1st try, always starts 2nd try
Old 09-07-10, 01:46 PM
tomtheslac
tomtheslac's Avatar
Default Wont start 1st try, always starts 2nd try
Starting to get a little fustrated now.. need a hint.
Replaced fuel lines and fuel filter. Cleaned TB and AFS. Plugs and wires check out. It stubbornly will not start the first time when the engine is even slightly warm. Tested VSV and it checked out, but I went ahead and replaced it anyways. Problem still persists. And the fuel pump resistor is bypassed for the car to run smooth. I am thinking fuel pump?? Anyone have similar issues?
Car runs smooth, no other running issues....
Old 09-07-10, 03:12 PM
hobojoe
hobojoe's Avatar
What year is it? I just got my service manual if its a 89-92 I can help ya out. Maybe fuel pump to me what sounds more likely for what you said though is a Pulsation Damper or the pressure regulator(more likely).
Old 09-07-10, 03:18 PM
tomtheslac
tomtheslac's Avatar
Sorry,it is a 91. Guess that could make sense. I believe there is a test for the damper, but not sure how to test the pressure regualtor. Guess I have to buy a pressure gauge or swap it out...
Thanks for the help.
Old 09-07-10, 03:43 PM
hobojoe
hobojoe's Avatar
Yea I have the shop book sitting right infront of me and there is no test for the regulator. Though to really help troubleshoot this it would be a good idea to find out what your fuel pressure is at when you try and start it.
Old 09-09-10, 02:32 PM
tomtheslac
tomtheslac's Avatar
Fuel pressure regulator $150 so I guess I will start with a can of Seafoam....
Old 09-09-10, 02:37 PM
akitomk3
akitomk3's Avatar
Cold start injector maybe? I'm guessing but that was the problem on one of my supra i had. Would never start on 1st try, then i cleaned the cold start injector and then it starts on the 1st.
Old 09-09-10, 07:56 PM
tomtheslac
tomtheslac's Avatar
Seems to be getting better bit by bit...but thanks, I will look at the cold start injector next. Pulsation dampener test passed ok, so here's hoping for he miracle of Seafoam!
Old 09-13-10, 10:14 AM
tomtheslac
tomtheslac's Avatar
Cold starts are never a problem. Would this injector cause problems with hot starts? I don't think I have a fuel pressure problem, since if pressure would bleed down overnight, the car would have an issue starting in the morning. Yet that is when it fires up no problem. I think I will swap coils next, maybe I have an intermittent contact problem when things heat up...but I am grasping at straws here...
JohnCarter
10-14-18 06:34 AM
dale53
Performance & Maintenance
14
08-07-16 04:53 AM
tarheeldad
05-21-15 11:42 AM
mungrin
01-01-14 01:14 PM
na4now
10-04-07 11:42 PM
Quick Reply: Wont start 1st try, always starts 2nd try
