brake pad sensor/wire...need a little help.
Old 08-22-10, 01:39 PM
Mega
Mega's Avatar
Default brake pad sensor/wire...need a little help.
my brake pad sensor light is on in my cluster, my 95 ls400 has new pads, and rotors all around. so that means i probably broke one of the sensors.
is there a way to bypass this sensor so the light goes off?
or am i forced to buy a new sensor?
Old 08-22-10, 02:45 PM
Kansas
Kansas's Avatar
Some people have rigged the sensors by connecting the two wires leading to a brake wear sensor or the wires at the sensor itself to complete the circuit and shut off the warning light. Or you could buy a new sensor (front: part # 47770-500301; rear: part # 47771-50060) from http://lexus.sewellparts.com/ with your ClubLexus discount for $45.32 (front) or 53.69 (rear).
If your brake pads last as long as the ones on my 00 LS do, you won't need another sensor or a set of front pads for another 70,000+ miles or rear pads for another 125,000+ miles. One can squeeze a lot of miles out of brake pads on these cars and probably save money overall by letting the pads wear down until the warning light/message comes on.
Old 08-22-10, 03:37 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
^this, just twist the wires together, solder them, and heatshrink them.
Old 08-22-10, 04:04 PM
Mega
Mega's Avatar
good info. thanks guys.
Old 08-29-10, 08:25 AM
Mega
Mega's Avatar
ok, so i took my wheels off....i am not seeing a sensor anywhere.
i can see the abs sensor, that goes to the hub, but i can not find anything else.
where is this brake pad sensor located?
Old 08-29-10, 08:36 AM
Mega
Mega's Avatar
ok, i found the ucf20 brake diy writeup, there is an image in there that shows the sensor very clearly.
it seems as if my ls400 does not have these sensors on it? im wondering why my light didnt come on until after i did my brake job?
Old 08-29-10, 08:56 AM
Kansas
Kansas's Avatar
The sensors are only on the right side front and rear brakes. Did you at least find the wires leading to them?
Old 08-29-10, 11:50 AM
LexChamp
LexChamp's Avatar
http://cgi.ebay.com/ebaymotors/New-L...Q5fAccessories
If I was you I would keep the sensor. I just replaced mine after my mechanic broke mine, light is off now. If the car came with it, why not not keep it as original as possible. It's only a few $$$$
Old 11-07-12, 07:16 AM
iamcandyca
iamcandyca's Avatar
So my 2010 ls460l only has one front brake sensor? Great! Is it ok to have Toyota or a non Lexus replace my sensor n or brakes?
Old 11-07-12, 08:27 AM
Shmee
Shmee's Avatar
Ummm, I'm not familiar with the 2010 LS460s but this discussion is pertaining tot he UFC10-21 models.
But what is wrong with only having one sensor, or were you happy it only had one sensor?
It's simply a warning sensor designed to be replaced with every set of pads. Often, quality OEM replacement pads come with the sensors and do not require you to purchase them separately. if you are buying jobber parts, typically you wont get sensors.
Old 11-07-12, 02:11 PM
PureDrifter
BahHumBug
the proper place to ask or look for an answer would be here: https://www.clublexus.com/forums/ls4...nd-ls600h-178/
This is the LS400 forum and it is unlikely that any of the information found here will cross over to your LS460.
G2Lexus
01-26-15 05:51 PM
Banshee365
01-22-10 01:19 AM
tbilisi79
05-03-09 02:03 PM
billy boi
07-15-05 06:12 PM
Quick Reply: brake pad sensor/wire...need a little help.
