LS400 power steering pump
Old 08-21-10, 04:26 PM
jerryparks
jerryparks's Avatar
Default LS400 power steering pump
Where do I find the procedures for removing the power steering pump?
I also would like to obtain a Haynes manual for my LS400.
Thanks for your help!
Old 08-21-10, 05:20 PM
Kansas
Kansas's Avatar
Instructions are at http://www.lexls.com/tutorials/steer...mpremoval.html
Old 08-21-10, 08:07 PM
turboomni
turboomni's Avatar
I got a factory service manual CD for my LS400 online at Ebay for 25 bucks.
Find your year and you are set
Old 08-27-10, 04:23 PM
jerryparks
jerryparks's Avatar
Default power steering pump removal problem
In the process of removing my PS pump. Having trouble removing the high pressure bolt on the left side of the pump and the bolt over the alternator.
These bolts are on so tight, I broke my light duty cheater bar on the one
over the alternator. I'm worried about rounding off the bolts, so I would appreciate any suggestions as to a sucessful removal. Thanks
Old 08-27-10, 04:35 PM
jerryparks
jerryparks's Avatar
I'm in the process of removing my PS pump. I have two bolts that I am having a hard time removing. The high pressure line bolt on the left side of the pump will not come out and the bolt over the alternator. I broke my
light duty cheater bar on the one over the alternator. I worried that I might round off the these bolts and am open to suggestions on a successful
removal. Thanks!
Old 08-27-10, 06:25 PM
LiCelsior
Retired
LiCelsior's Avatar
thats wierd...it was straight forward when i removed it.
Old 08-27-10, 08:02 PM
dfkd
dfkd's Avatar
Did mine a couple weeks ago and those two were the least of my worries. The two that go into the block were the worst for me.
Not even sure what to suggest...
What do you mean by "will not come out"?
Old 08-27-10, 11:01 PM
AzHotLS
AzHotLS's Avatar
Give PB Blaster a try. Spray it on, let it soak for a few hours. You may have to repeat a couple times to let it get into the threads.
Old 08-28-10, 11:25 AM
deanshark
deanshark's Avatar
For the bolt make sure you are using a 6 point socket not a 12 point. It wont strip the bolt that way. Impact sockets are even better. I didn't have that problem with mine either. But yea, PB Blaster should help. With the presure hose, ya might want to take out anything that might give you more room to swing the wrench.
I hate to say this but, make sure you use the right size wrench. (metric sucks)
Old 08-28-10, 01:14 PM
jerryparks
jerryparks's Avatar
Default High pressure line bolt problem
This bolt will not come out. I have tried heat, Blaster, beating on it with a
sharp object, etc. - No results. It is a counter clock wise bolt, is'nt it.
The bolt has copper rings on it-I think . All I end up doing when I put a lot of pressue on it is break loose the other screw in piece that the stubborn bolt screws into. What am I doing wrong?? !!
Old 08-28-10, 02:17 PM
jerryparks
jerryparks's Avatar
Default pressure bolt is OUT -PTL
It finally came out. It sure would have been nice if the tutorials had indicated that the high presssure bolt has a "key" built into the copper
rings that must be rotated to remove the bolt. After I rotated the "Key"
it came right out - no problem. This important step should be added to the tutorials -- it would have saved me a lot of time and frustration.
Old 08-28-10, 11:25 PM
AzHotLS
AzHotLS's Avatar
So the key was the key, interesting. Good find and for letting us know.
Old 08-30-10, 10:40 AM
dicer
dicer's Avatar
Impact wrench
Old 08-30-10, 10:41 AM
Och
Och's Avatar
Big wisegrip. Seriously.
Old 08-30-10, 12:16 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Jerry, I've merged your three posts about this together into one single thread. Please just create one
socalturbo
03-02-21 10:23 AM
LS400BOY
16
03-08-16 05:47 PM
Wakko47
01-28-13 03:12 AM
Norbecke
06-27-12 08:53 PM
Quick Reply: LS400 power steering pump
