CEL Keeps going on and off
Old 08-07-10, 11:57 PM
rmoriar1
rmoriar1's Avatar
Default CEL Keeps going on and off
For some reason my CEL on my 2000 LS keeps coming on stays on for about 100 miles than goes off randomly. My buddy says it may be the fuel vapors. Anyone have the same problem and know what it is from or what the solution to keeping it off may be?
Thanks
Old 08-08-10, 12:13 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
maybe you should have the code read so you KNOW what the problem is instead of basically asking us to use the Force to figure it out
there are LIBRARIES full of the different codes and causes of OBDII cels...
Old 08-09-10, 01:15 PM
qewani1
qewani1's Avatar
Code should be pending, use a code reader! post the CEL code here.
Old 08-10-10, 02:57 PM
rmoriar1
rmoriar1's Avatar
The guy said it is the catalytic converter. If it doesnt stay on permanently do i still need to get it fixed? Whats the cost of repair?
Old 08-10-10, 03:52 PM
PureDrifter
BahHumBug
Forum Moderator
you're on your own. there's no code that definitely says its a catalytic converter problem. post the code so we can help or continue to potentially get screwed over by your mechanic.
until then, im out.
Old 08-10-10, 06:53 PM
LexChamp
LexChamp's Avatar
Dude, go to Autozone or Advance Auto and get a free reading........Why are you Playing Russian Roulette
Old 08-10-10, 08:11 PM
rmoriar1
rmoriar1's Avatar
ok well the guy reset it so its off. ill take it to autozone and get the code next time it comes on.
Old 08-11-10, 07:12 AM
python
python's Avatar
code is still in there....ill go out on a limb and say one of ur 02 sensors is bad
Old 08-11-10, 05:51 PM
rmoriar1
rmoriar1's Avatar
I went to autozone this is the print out they gave me. Code is P0430, Definition: Catalyst efficiency below threshold. Probable cause: 1) Failed catalytic converter 2) Ignition system malfunction 3) Fuel system malfunction.
Old 08-11-10, 06:33 PM
PureDrifter
BahHumBug
Forum Moderator
check for exhaust leaks, most common cause of that code.
SCORP69
IS F (2008-2014)
03-07-19 12:04 PM
ididit
RX - 1st Gen (1999-2003)
05-06-13 08:32 PM
IS300kidd
IS - 1st Gen (2001-2005)
11-29-12 04:35 AM
-Future-
01-26-10 10:50 PM
Quick Reply: CEL Keeps going on and off
