new engine mounts for my 1999 LS400
Old 07-24-10, 08:42 PM
billydpowe
billydpowe's Avatar
Default new engine mounts for my 1999 LS400
My nephew just finished installing my new motor mounts.
the old 140k mounts came out in pieces.
Old 07-24-10, 09:19 PM
RA40
Super Moderator
RA40's Avatar
I'm due for some too. Those look pretty bad. Did you notice vibration in the gear selector prior?
How about your tranny mounts?
Old 07-25-10, 05:51 AM
billydpowe
billydpowe's Avatar
yes, I had some, it was worse before I replaced the tranny mount in May, but now it is just rock solid... my 97 is next
Old 07-25-10, 08:41 AM
biggiepee
biggiepee's Avatar
Default engine mounts
I have to replace my mounts on my 2000. Did you use oem or aftermarket mounts. How long did it take? the mechanic i went to wants to charge me for 4 hours of labor.
Thanks
Old 07-25-10, 12:48 PM
billydpowe
billydpowe's Avatar
I used aftermarket ebay 130381674024 from eurasia parts. $130 for BOTH shipped, takes 3 hours even if you dont know what you are doing. he can probably do it in two, we could if we had a lift instead of floor jacks and jack stands, on a creeper....
Old 07-25-10, 01:15 PM
JBrady
JBrady's Avatar
Well, at 165k I must REALLY be due.
No obvious vibration or noise problems and my trans mount is original as well.
Strange that the mounts have no provision to keep engine secure once cusion is worn/broken.
Old 07-25-10, 02:56 PM
billydpowe
billydpowe's Avatar
it is so tight in there, there is no place for it to go.. but the movement makes sounds that will disappear
Old 07-26-10, 03:19 AM
j three
j three's Avatar
They have a package with the tranny bushing as well. http://cgi.ebay.com/ebaymotors/New-L...Q5fAccessories
Old 07-26-10, 08:11 AM
billydpowe
billydpowe's Avatar
I just ordered the mounts for my 97, and new strut rod bushings for my 99, I replaced the SRB on the 97 a couple of weeks ago..
Old 07-29-10, 02:34 AM
skperformance
skperformance's Avatar
I put in OEMs as they are cheap and should last fine.
Mine also was cracked on the passenger side (?) .
Easy way to tell is rev the engine with the brake on and listen for the thump when you release as the engine sits back down.
Old 07-29-10, 06:26 AM
biggiepee
biggiepee's Avatar
when you replaced the mounts did you have to replace the engine stabilizer or just the mounts themselves. Also how did the aftermarket mounts from ebay fit? im still deciding if it is worth it to get the oem mounts.
Thanks
Old 07-29-10, 08:43 AM
billydpowe
billydpowe's Avatar
just the engine mounts, and they look and fit the same.
on my SRB's I used OEM $91. from Park Place (I live close to them, no shipping$), but I ordered polyurethane bushings from mybushings.com for my 99, just to see the difference, they were $84, shipped.
Old 11-19-13, 08:36 PM
bees
bees's Avatar
Bringing up an old thread... But how are ur mounts holding up now? Any difference with the poly mounts?
Old 11-20-13, 06:57 AM
billydpowe
billydpowe's Avatar
Glad you ask.... you can look up the thread.. polys were TERRIBLE!!!. left them in about 10 days, and it rode like an old ford.... took them out and went OEM and got my Lexus back again..
the engine mounts are still fine, no issues..
polys have no cushion... no give, just HARD CONTACT.. enough said...
Attached Thumbnails new engine mounts for my 1999 LS400-polybushings.jpg   new engine mounts for my 1999 LS400-srbmk.jpg
Gskis
GS - 1st Gen (1993-1997)
03-21-10 12:26 PM
96ls400ky
03-13-08 07:57 PM
richonenz
10-23-07 04:24 PM
Pagong
12-01-04 10:18 AM
CleanSC
Performance & Maintenance
04-07-04 10:00 AM
Quick Reply: new engine mounts for my 1999 LS400
