help! can't get rear rotors off my 91LS
Old 07-14-10, 02:06 PM
Max Power
Registered User
Max Power's Avatar
Default help! can't get rear rotors off my 91LS
Alright so I hammered them well with a hammer and I can move them around pretty good, however, they just won't come off. Is there an adjustment somewhere for the parking brake? Any ideas??
Old 07-14-10, 02:08 PM
LiCelsior
Retired
LiCelsior's Avatar
u removed the screws that holds the rotor to the hub?
Old 07-14-10, 02:19 PM
Max Power
Registered User
Max Power's Avatar
Yes I have. The rotors wouldn't be moving out towards me if I hadn't. I can only assume something inside is holding the rotors on. Possibly the parking brake (which I never use, but I've only had the car a year).
Old 07-14-10, 02:27 PM
PK_Celsior
PK_Celsior's Avatar
hmmmm thats odd nothing should be holding the rotor. so you disassembled the caliper itself and removed it and the bracket thats also holding the caliper correct.
http://www.lexls.com/tutorials/brake/rbrotor.html
check out this tutorial should help you out on your journey
Old 07-14-10, 02:30 PM
Max Power
Registered User
Max Power's Avatar
Yeah, I followed that, like when I did my fronts a few months ago. As he said, the rears would be hard to remove. There were rusted in place but I broke them free and I can slide them out about half an inch to an inch, but then they get stuck again.
Old 07-14-10, 02:34 PM
PK_Celsior
PK_Celsior's Avatar
haha dang thats intense all i can say is keep pounding away or use a pry bar but there shouldnt be anythin holding the rotor back to tell you the truth
Old 07-14-10, 02:39 PM
Max Power
Registered User
Max Power's Avatar
Yeah it sucks!! I have to find the adjustment for the parking brake. Its all that I can see it being.
Old 07-14-10, 02:45 PM
LiCelsior
Retired
LiCelsior's Avatar
just keep hitting it.
Old 07-14-10, 04:25 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
BFH time!
Old 07-14-10, 06:49 PM
Max Power
Registered User
Max Power's Avatar
Ok I got them off. The parking brake was what was keeping the rotors on.
As I finally got the drivers side rear rotor off something with the parking brake mechanism snapped and everything was loose.
I really don't have time or money to be fixing this now so i just disassembled the entire mechanism. I never use the parking brake anyway.
haha
BLKonBLK98
BLKonBLK98's Avatar
i had this problem as well. it was just a matter of hammering at it and pulling it straight (vs. at an agle).
Old 07-15-10, 08:28 PM
lev00221
lev00221's Avatar
There are several threaded holes on the rear rotors. You can insert an appropriately sized screw into these and tighten it. This will seperate the rotor from the brake mechanism and hub underneath. I think that these were designed into the rotor the type of issues you described.
Old 07-16-10, 02:59 AM
PureDrifter
BahHumBug
^this works the best, forgot about those lol. use an 8mm bolt+socket (screws will strip, ask me how i know )
you can use the method i described in this ancient thread if you arent sure which holes we're talking about. same or the front vs. rears.
https://www.clublexus.com/forums/ls4...-00-ls400.html
chewbears
Suspension and Brakes
06-28-09 01:11 AM
rerose
05-02-06 07:00 PM
TriniLex
08-09-05 07:12 PM
nick778
08-11-04 07:47 PM
siaxazn
07-11-04 11:30 AM
Quick Reply: help! can't get rear rotors off my 91LS
