Weird shifting and throttle issues.
Old 06-02-10, 10:42 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
pm licelsior
Old 06-05-10, 03:41 PM
Sixdown
Sixdown's Avatar
Installed another throttle body. Same thing.
Adjusted the kickdown cable numerous times to numerous positions.
Same thing.
What in the world could it be?
Another thing I've noticed. Occasionally when I start the car with the engine cold it shifts normally until I stop the car and restart it after it has already warmed up, like when I go to a gas station. After I restart the car it shifts up to Overdrive immediately. Maybe it's related to engine temperature then.
Old 06-05-10, 04:16 PM
Sixdown
Sixdown's Avatar
Here are my current engine codes after installing and adjusting the new TPS properly on the newer throttle body:
21 - Main oxygen sensor signal (on left bank)
25 - Air-fuel ratio lean malfunction
41 - Throttle position sensor signal
There are no transmission codes.
Old 06-05-10, 05:19 PM
PureDrifter
BahHumBug
TPS wiring?
Old 06-07-10, 03:22 PM
Sixdown
Sixdown's Avatar
Today I removed the throttle body again, cleaned it entirely out, checked the adjustment screws, checked if everything was in place, tested the TPS using the Ohm method, reset the ECU, and cleaned out the IACV.
Nothing has changed. The idle is still at around 2000rpm, there seems to be a minor misfire when I take off from a stop, and it shifts into O/D too fast.
I'm beginning to suspect that the ECU decided to take a crap.
Old 12-05-13, 12:54 AM
zemtem
zemtem's Avatar
Hi there did you ever solve this issue? If so what was it as I'm having the same? Thanks
Old 04-10-14, 08:30 AM
dhhd
dhhd's Avatar
Check the post in the LS400 forum about " All my crazy electrical issues gone! Leaking ECU capacitors" I have had success on all three of my Lexus vehicles with the leaking ecu capacitors. Check it out, follow the directions exactly and you will be fine. It's a super cheap repair that almost always cures these weird issues. I'm talking like 4 dollars in parts from the correct supplier. LsCowboyLs and Japanese ecu engineer Yamae are the ones who found this information.
Old 06-09-14, 10:13 AM
297xxxl400
297xxxl400's Avatar
Change your shift solenoids mine were melted cost me 150 from transstar comes with the solenoids attacted install a breeze
Old 06-09-14, 10:16 AM
297xxxl400
297xxxl400's Avatar
shift solenoids go change them now my car was doing the same thing
Hawkeye921
06-25-19 04:53 PM
Androman
RX - 1st Gen (1999-2003)
07-16-18 02:27 PM
lexixel
07-15-17 01:14 PM
AdamOj
GS - 1st Gen (1993-1997)
11-19-14 05:07 PM
kuziwk
03-16-11 07:06 PM
Quick Reply: Weird shifting and throttle issues.
