changed radiator ls400 1990
Old 05-16-10, 05:05 PM
iamviolet
iamviolet's Avatar
Default changed radiator ls400 1990
bought a new radiator from ebay for 80$ and just installed it.
couldnt believe how dirty and ugly the old one was. so had to take a pic of it.
also installed a new power steering pump.. so much easier with the radiator out.
Old 05-16-10, 05:08 PM
LiCelsior
Retired
LiCelsior's Avatar
yea thats why when u actually flush ur coolant. its best to remove 2 12mm bolts and a couple clamps to remove the rad and clean it with your garden hose.
Old 05-16-10, 05:59 PM
iamviolet
iamviolet's Avatar
my top seal cracked on my old unit..
Old 05-16-10, 06:12 PM
avalon42
avalon42's Avatar
I used a car wash and pressure washed that thing. It died 9 months later when the top tank had a minor crack that just got worse over time.
It's really dirty from that foam insulator thing that goes around the mouth of the radiator.
Old 05-16-10, 09:59 PM
Bill Dowd
Bill Dowd's Avatar
I recently visted a tech at crown lexus in Ontario Ca and he showed me how to remove the rubber between the radiator and air cond condensor and my was half full of dirt I had to pick it out for 2 hours and high powered sprayed in a $2.00 car wash and now it's clean so if you have 100-200,000 miles check down in between the radiator and air condensor for dirt like you see above my was the same my radiator is still working ok so far I use toyota red fluid antifreez and distilled water 50/50 I drain my block and radiator every 2 years and with 241,000 miles I have all the same hoses and radiator I do check it often due to age . Remember you have to cool the transmission and engine and if your radiator looks like the one above expect PROBLEMS OF OVER HEATING BOTH.
Old 06-14-10, 07:33 PM
mrwinkle
mrwinkle's Avatar
hey can you tell me what store/seller you bought it from on ebay and tell me how it is holding up? I need to purchase one because mine is bad.
Old 06-15-10, 11:57 AM
damon
damon's Avatar
I have seen 2 instance of radiators looking almost that bad on the LS models my family owns. My initial reaction was that it looked as if they had been in a flood!!
Old 06-15-10, 05:59 PM
Lexozz
Lexozz's Avatar
A radiator looking like this also can cause over heating especially in the summer time with or without A/C on.
warminwisc
07-21-13 07:23 PM
gandro
Automotive Care & Detailing
01-29-10 09:18 PM
demonboy
04-23-08 09:47 AM
suprandsc
Performance & Maintenance
08-27-06 11:03 AM
Quick Reply: changed radiator ls400 1990
