Hissing noise under car
Old 05-07-10, 07:56 PM
Banshee365
Banshee365's Avatar
Default Hissing noise under car
1996 has a hissing noise under the car. It's gone at idle but if you rev it a little it starts hissing. It's not a gradual start like a leak would be. It sounds like a diaphram doing back somewhere in the vacuum system or something. If I put my head under the drivers door and reach in and rev with my hand it's loud. I havn't put the car up on ramps yet and done it but I'm wandering if anyone here has had experience with this. There are no check engine lights and the car runs great. It's due for a timing belt and water pump job within the next month or so which I'm going to be doing when I can afford the parts. If there was a vacuum leak somewhere causing the hissing I'm sure there would be a CEL of some sort. It sounds like it's coming from around the cats but I don't see how it would make a sound like that. Sometimes it will stop when you rev above a certain point but it almost alway's doesn't make any noise at idle. Any ideas?
-Kelly
Old 05-07-10, 08:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
exhaust leak.
Old 05-07-10, 09:28 PM
Dave Mac
Dave Mac's Avatar
I second that - an exhaust leak.
Dave Mac
Old 05-07-10, 09:36 PM
Banshee365
Banshee365's Avatar
Okay. I guess I'll pull the car up on ramps when it get's home tomorrow evening and crank it up when cold and feel around for a leak? Won't take long until it's hot though. May be able to see a burn mark or something if it is in close proximity to anything else.
Old 05-08-10, 09:22 AM
amcdonal86
amcdonal86's Avatar
If there is an exhaust leak, you'll probably also notice a somewhat gassy smell. Also, you should be able to feel air rushing out of the leak.
Old 05-09-10, 06:55 PM
billydpowe
billydpowe's Avatar
check the lower EGR tube, mine was leaking on the 97LS, removed the passenger side cat/converter, and lowered the rear crossmember and let the motor sag to get to the bolts. the cat took longer than the tube.
deeken
GX - 1st Gen (2004-2009)
12-17-19 09:11 PM
Spiziked23
GS - 1st Gen (1993-1997)
08-11-16 02:07 PM
kidlex93
RX - 1st Gen (1999-2003)
04-17-11 02:10 PM
BadViper22
23
08-12-07 12:29 PM
Metlupass2
07-24-07 10:45 PM
Quick Reply: Hissing noise under car
