one more tire question
Old 05-05-10, 11:39 PM
2000 ls400
2000 ls400's Avatar
Default one more tire question
can i run 255/45/18's on the front and 275/40 18's on the back of a 2000 ls with sc430 wheels with no rubbing, stock height? thanks as always.
Old 05-06-10, 12:48 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
those tires will not fit properly on stock SC430 wheels.
and those wheels wont clear the stock brakes without minimum 15mm spacers.
Old 05-06-10, 04:35 AM
Schnitz
Schnitz's Avatar
Tire sizes are fine though.
Old 05-06-10, 05:53 PM
2000 ls400
2000 ls400's Avatar
so what if i do 245/45/18 with 15mm spacers in the front and 255/45/18 with 25mm spacers in the back. will that look and ride good without rubbing. i really appreciate all the help.
Old 05-07-10, 05:10 AM
Schnitz
Schnitz's Avatar
The page in this thread should help:
https://www.clublexus.com/forums/ls4...-setup-24.html
Otherwise read through that entire thread.
Old 05-07-10, 12:26 PM
PureDrifter
BahHumBug
in terms of diameter? yes.
in terms of FITTING on the non-staggered 18x8, not so much. you may be able to squeeze the front tires onto those but the rears will be over 1" out of spec for that rim width, and will not fit safely afaik.
2000 ls400
05-24-10 07:13 PM
robertrios
RX - 1st Gen (1999-2003)
01-25-10 08:50 PM
Champstar
08-31-09 06:50 PM
GiantsFan
02-06-09 06:21 PM
Quick Reply: one more tire question
