Timing belt Mistake - cams 180 degrees off
Old 05-04-10, 04:09 PM
gripmatic
gripmatic's Avatar
Default Timing belt Mistake - cams 180 degrees off
Replacing belt on a 94 LS400.
I am at the point of putting the belt on.
Problem is: I pulled the TB of with my cam gears 180 degrees off. Can I just rotate the Cam gears 180 degrees, or do I need to rotate the Crank 180 also?
I am guessing I do need to rotate all, but I want to be sure.. thanks
****, I feel like an ***.
Old 05-04-10, 04:11 PM
gripmatic
gripmatic's Avatar
I am thinking Rotate Crank 360, and Cams 180?
Old 05-04-10, 08:59 PM
gripmatic
gripmatic's Avatar
I just rotated the cam gears and left the Crank pulley where it was... we'll see
Old 05-05-10, 04:57 AM
Och
Och's Avatar
Just make sure crank gear and cam gears align with the marks. You can rotate them separately on 90-94 model, it is a non-interference engine.
Old 05-05-10, 06:29 AM
python
python's Avatar
yes...just align all the marks and put the belt on
draider
10-26-22 08:38 PM
dawson128
04-16-19 12:00 AM
SenecaRex
12-31-15 03:55 PM
Sololock
26
05-30-12 08:56 AM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
Quick Reply: Timing belt Mistake - cams 180 degrees off
