Bushings for front suspension for 95+
About to replace my power steering pump and rack (leaks) on a 95, and would like to swap out all bushings as well to smooth out and tighten the ride. Only thing I am sure about is ADUS 531 is for front strut rod for 95.
But for lower control arm (or lower suspension arm), what is the ADUS P/N for it? On mybushings.com it says ADUS 530 is only good for 94 or before, but somewhere on this forum someone had said ADUS 530 is good until 2000. Please confirm or provide the right part.
And for stabilizer/sway bar, is there a replacement bushing? Found Daizen but supposedly for 94 or before as well. And should I replace the stabilizer bar link (or sway bar link) if I want to tighten up the handling?
Thanks.
Thanks.
Only use ADUS bushings if you don't mind alot of squeaking. If you want it super quiet then your only option is to go OEM. For the LCA bushings you'll need to replace the entire LCA as Lexus doesn't sell the bushing alot. The strut rod bushings are available seperate and must be pressed out and in.
