Vibration and rattling noise from one of the accessory\idler pulleys?
So my car developed some soft of rattling and vibration at high engine RPMs. The vibration is felt though the whole drivetrain at high RPMs, at 5000 rpm it feels like something's about to fall apart.
When I disconnect the accessory belt, the noise stops, and the engine revs up smooth. So its most likely that its one of the pulleys/accessories, but they all spin smoothly by hand. Is there a way to detect which one is doing it?
Also, it seems to only happen when the car is in drive. At idle it seems to rev up smooth.
insane but interesting. the way i figure out which pully is bad on my **** is wiggle the hell out of them to see if i can feel a clunk or something or with the belt on and engine running use a stethescope with long metal attachment to listen to each pully. if you cant figure it out like that youll have to take them off and inspect them. it can be any of them but the culprit is more than likey the tensioner. or the ps pump. or the idler. or the water pump.
if your harmonic balancer got f-ed up it would prob shake like you are talking with or with out the belt so ya i would nix that too. so whats left? ps, idler, tension, alternator? id have to go outside in the rain to look..
hmm so with the fan idler would the fan be non operational with the belt off? the fan itself would also need to be ruled out. ive seen idlers go bad but they usualy just make a lot of noise and not a lot of vibration. the tension could def be the culprit and would be easier to rule out than the alternator, ps pump, or ac compressor.
