Should I rescue an 1991 LS from being scrap
Old 04-06-10, 08:00 PM
chilejeep
7th Gear
chilejeep's Avatar
Default Should I rescue an 1991 LS from being scrap
Several issues has caused a local family to consider just scrapping the car. I hate to see that happen and I'm considering buying it for $300-400.
Needs front rotors
drivers door handle
power steering pump
speedo and tach do not work but gas and temp do?
ran and drove ok for about 5 miles on my way out of town got up to about 60 then the vibs started and continued for the rest of the drive. Pretty severe cant understand what could cause vibrations after warm up. Along with the vibration came an odd smell. Don't know if it's worth saving or even parting out and advice would be great.
Nathan
Old 04-06-10, 08:17 PM
ck90211
ck90211's Avatar
I recently rescued a 96 from the junkyard (bought it for parts for my 95 daily runner, ended up fixing because father-in-law wants it). Ended up putting $4000 in it, for a salvaged engine (snapped timing belt), new timing belt and tensioner, fluids, new air struts (all 4 corners), new brakes and rotors, new fan clutch, freon refill, etc..... Everything is seriously discounted because my friend (whose mechanic did the work for the cheap) got me dealer discount on all parts we purchased. And we have gone the route of Rockauto, Autozone and some Toyota OEM parts.
Would I do it again? Nope. Would rather put all that into a 98-00. But is the 96 running good? You bet, the salvaged engine is only 46K miles and with new air struts the car runs like a $60K car again. Definitely better than any $30K new car one can buy today.
Old 04-06-10, 08:31 PM
chilejeep
7th Gear
chilejeep's Avatar
Defiantly the junkyard DIY route, I guess my real concern in the vibration. Defiantly don't intend on restoring to like new condition just get it safely drivable. More of give me something to do type project.
Old 04-06-10, 08:36 PM
amcdonal86
amcdonal86's Avatar
Are you doing this for the sake of the car, or for your own sake? If you are doing it for the sake of the car, I would say don't do it. But if you are doing it because you think you would enjoy the car, why not?
As for the vibrations, I would check the transmission/engine mounts, and front suspension bushings, especially the front strut rods.
Old 04-06-10, 08:45 PM
LiCelsior
Retired
LiCelsior's Avatar
i got some front and rear rotors for your car, cross drilled and slotted. $160 shipped.
i also have a driver side handle but that one is out of whack also. also have a power steering bump but im sure the high pressure line is fubar'd. the cluster is an easy $5 fix with some soldering, and your vibration is probably due to unbalanced wheels.
Old 04-06-10, 10:50 PM
avalon42
avalon42's Avatar
Needs front rotors
drivers door handle
power steering pump
Nathan
Like rotten eggs? Or burning oil? Describe the smell.
Old 04-07-10, 03:21 AM
Acidic
Acidic's Avatar
Yah that vibration could be anything. I had a frozen caliper and bad ball joints but there are many possible problems... Since you have to warm it up and it's severe it'd get it on a lift and check for sticking calipers...
Also before you make the decision GET IT ON A LIFT and thoroughly check it out. I bought a 1991 for $1900 on a test drive and alot of the problems didn't crop up for several days...
Old 04-07-10, 08:55 AM
chilejeep
7th Gear
chilejeep's Avatar
The smell I suppose best described as hot metal. I was trying to pinpoint it but to no avail. I would love to get it on a lift but I'm sure this small town doesn't have one. Up on jack stands in my garage will have to do if I buy it.
Old 04-07-10, 06:35 PM
j stuff
j stuff's Avatar
Mite be worth it alone just for parting it out
Old 04-07-10, 07:48 PM
chilejeep
7th Gear
chilejeep's Avatar
Kind of what I was thinking any thoughts on particular pieces that sell well.
Old 04-07-10, 09:07 PM
j stuff
j stuff's Avatar
Headlights, tail lights and the wheels/tires alone will break u even. Checkout the ls400 for sale section for part out cars. All of us need something
Old 04-08-10, 07:56 PM
chilejeep
7th Gear
chilejeep's Avatar
Well look like it will take $375 to bring it home. It didn't seem to pull like a stuck caliper. Is it ok to dolly these don't really want to drive it 30 miles to my warehouse.
Old 04-09-10, 01:02 AM
luvlexls
luvlexls's Avatar
where r u located? I cd use a power steering pump, all lights across front of car, airbags and a few other items...let me know if you can/want to part it...
chris
Old 04-09-10, 09:21 PM
chilejeep
7th Gear
chilejeep's Avatar
Sorry I'm never towed with a dolly before can I just lock the steering and tow it backwards?
Old 04-09-10, 09:23 PM
LiCelsior
Retired
LiCelsior's Avatar
why not just tow it from the rear?
Quick Reply: Should I rescue an 1991 LS from being scrap
