91 LS400 Sub 2 or 4 ohm??
Hey All
I read ion anther post that my stock Sub should be a 10inch 2 ohm sub. Is this correct? I was putting in gas today and out of curiosity I decided to look at the sub. I discovered tha the previous owner had replaced the sub with anoth Pioneer sub but it is rated at 4 ohms and has a sticker on it marking $79. Obviously not a high quality speaker. I need to look up the model number but my question is :?
If I replace this 4 ohm sub with a quality 2ohm one will I get a significat upgrade. Right now I do get some bass but I do not believe Im getting my 10inches worth!
My goal is to get the most out of my system with out building a box or adding amps.
Thank you in advance for you time and advice.
Jerry
Jerry
PlatinumSC
05-04-04 03:39 PM
