LS 400 questions
Old 05-28-02, 02:38 PM
Bobby K
Bobby K's Avatar
Default LS 400 questions
OK, I changed the oil a couple of days ago. The next day when I started the car, the engine light and the trac light was on. I had to disconnect the battery in order to clear the computer. I did the oil myself. I did not touch anything and certainly there is no leak at all. Do I have to clear the computer every time I am doing some sort of work on the car? Also, does anyone know if there is a computer (affordable) that I can buy so I can read the codes of the engine? And as last, I will replace the brake rotors in the near future and I want to install cross drilled. Does anyone have any good recommendations? '92 LS 400. Thanks.
Old 05-29-02, 05:42 AM
mlevk
mlevk's Avatar
Default NO YOU SHOULDN'T HAVE TO
I change my oil all the time , 91 LS and never have a problem.
There's a sequence to get the engine codes , but I'll have to look
to find it or if someone have a manual they can help you out ?
There's a web site also to order cross drilled slotted rotor's but again I'll have to look for it I think they were 120 ea.
You can e-mail me if you like.
Old 05-29-02, 10:19 AM
mlevk
mlevk's Avatar
Hey Bobby , here's the site for croos drilled rotors
They on sale !!
http://www.optauto.com/webstore/prod...=yes&dept=1526
Old 05-29-02, 03:36 PM
hyperopt
hyperopt's Avatar
Default Re: LS 400 questions
Yes, there is one called a paper clip. A small jumper wire is also fine too. Jump T & E1 on the diagnostic connector and you're good to go. Do a search on engine code and you'll fine more details.
Prodigy249
11-24-16 06:45 AM
badfish667
05-17-15 05:02 PM
golfdog
02-15-06 09:12 PM
suloh
Maintenance
10-08-05 09:02 PM
azari
09-01-02 11:43 PM
Quick Reply: LS 400 questions
