red toyota antifreeze in first gen?
Old 02-18-10, 12:17 AM
J_LS
J_LS's Avatar
Default red toyota antifreeze in first gen?
i am in the process of a complete fix up on my 91 LS400 and was wondering if it would be okay to switch antifreeze to the red toyota coolant. i called the local toyota dealership and asked them if it would be okay to switch from the green to the red or pink and the advisor suggested i stuck with the green coolant because the red or pink has been known to cause "pitting" whatever that means... i wanted to gather some input from all you lexus buffs, thanks!!!
Old 02-18-10, 03:54 AM
iamviolet
iamviolet's Avatar
been using red in my 90 ls400 for years
Old 02-19-10, 06:01 PM
jcp2000
jcp2000's Avatar
i have red in mine my cousins a "toyota tech" at a dealer he put it in mine and its been running fine
Old 02-19-10, 10:46 PM
RA40
Super Moderator
RA40's Avatar
Most of them are cross compatible but for ease, using the same is preferred. Only one as having incompatibilities a spell back was GM's Dexcool/orange before it was reformulated. IDK how it is now. If you are going to do a drain and flush, Toyota's red coolant should be fine. Have the tech define what and where the pitting occurred.
I've used a variety of coolant over the years and have no complaints from any of them. Only gripe is the one oblivious tech who put Prestone into the Dexcool ruining it. It even had a sticker indicating "Only use Dexcool" and how does one miss orange coolant.
Old 02-19-10, 11:31 PM
J_LS
J_LS's Avatar
thanks for the input guys... i think i was mistaken, it might've been pink toyota antifreeze that he was thinking about, anyways red coolant here i come! haha...
Old 02-21-10, 06:03 AM
Bradster
Bradster's Avatar
Jumping in here...So "pink" can't be used in 1st Gen LS400?
Old 02-21-10, 07:01 AM
vdeleon
vdeleon's Avatar
"your coolant must contain ethylene-glycol type coolant for a proper corrosion protection of your engine that contains aluminum components. Use "toyota long life coolant or equivalent" quote from my 1999 LS400 manual word for word.
Jnsa540 (02-15-22)
Old 02-21-10, 08:35 AM
3UZFTE
3UZFTE's Avatar
GUYS, SEARCH!!!!!
Red is Ok for our cars, pink supersedes red, so Pink is ok to use too. Really though, people have documented that in none aluminum radiators Toyota coolant tends to deteriorate the innards, as opposed to the green stuff. I know my 92' LS400 radiator is aluminum so it's good to go, however I know some people have copper ones out there, and in that case I would stick with green. If you are budget minded, stick with green regardless of what radiator you have. If you want to be a stickler, like most of us, I just like supporting Toyota, so I use most stuff OEM when I can. Again, search, you will find more than enough answers.
Old 02-24-10, 03:23 PM
Bill Dowd
Bill Dowd's Avatar
i have been using THE TOYOTA RED ANTIFREEZ MIXED WITH DISTILLED WATER 50/50 AND I STILL HAVE MY ORIGNAL RADIATOR AND HOSES AFTER 18 YEARS AND NO PROBLEMS ALL I DO IS DRAIN THE BLOCK AND RADIATOR DON'T BACK FLUSH JUST PUT IN THE NEW ANTIFREEZ AND YOU ARE GOOD TO GO HERE IS SOMTHING INTERESTING TAKE OUT THE FOAM RUBBER AT THE TOP OF THE RADIATOR AND LOOK DOWN BETWEEN THE RADIATOR AND THE AC CONDENSOR AND SEE HOW MUCH JUNK HAS COLLECTED MY WAS A 1/4 FULL AND I BLEW IT ALL OUT .
gebo
Maintenance
06-09-15 01:06 PM
lextout
08-01-12 12:38 PM
voleduy
IS - 1st Gen (2001-2005)
29
09-12-10 09:05 PM
lexus114
11-04-09 12:46 PM
pizitz70
11-03-09 03:30 PM
Quick Reply: red toyota antifreeze in first gen?
