Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
brighter headlights for 1990 LS 400?
Thread Tools Search this Thread
Old 02-20-10, 10:45 PM   #46
sam12345
Trader Score: (1)
After reading countless hours on this I decided I am going to do the 9007 bulb and see how that works. To do hid you really need a light designed for it or do the projector conversion. To much hassle. I'll post my results once I try it.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
sam12345 is offline   Reply With Quote
Old 02-21-10, 08:04 AM   #47
python
Trader Score: (4)
python's Avatar
http://candlepowerinc.com/pdfs/9004_9007.pdf
python is offline   Reply With Quote
Old 02-21-10, 11:01 AM   #48
avalon42
Trader Score: (1)
avalon42's Avatar
Quote:
Originally Posted by Brandicus View Post
Want another opinion?
retrofit projectors from a newer model, its a huge DIY project or you can pay someone a grip to do it for you.
Its the most expensive and/or most time consuming of them all, but it also yields the light output of modern non-reflector based headlights basically from going blind to seeing everything.
Im nowhere near done on mine but just as an example. 2009 ls460 to 1993 ls400
Click the image to open in full size.
Cool. I like the recessed headlight look. You going to throw some clear corners on there too? The stock frosted ones look yucky.
avalon42 is offline   Reply With Quote
Old 02-21-10, 01:47 PM   #49
sam12345
Trader Score: (1)
yeah I read that article but I also read countless other ones and the 9007 seem like a good compromise. Maybe if it does not work I will go all out.
Old 02-21-10, 02:06 PM   #50
sam12345
Trader Score: (1)
another nice article on bulb performance
http://www.toyotanation.com/forum/t65571.html
http://aphnetworks.com/lounge/2009_c...treme_power_80
Old 02-22-10, 07:29 PM   #51
19psi
Trader Score: (0)
19psi's Avatar
i've had hid's in probably 10 cars since '98, and would never, ever, go back to any type of regular bulbs. HID or nothign!
definitely buy some HId's off ebay, theyre like $52 shipped these days, plug them in and never look back. btw, you want the 9004 bulb style. you won't have high beams, but you won't need them. seriously. you coudl get the "hi/low" style,b ut they don't work that well, and the wiring is a bit more complicated.
__________________
Dodge Ram cummins turbo diesel, 5 speed, 344 HP, 788lb.ft. 18/21mpg, shooting for 1000 lb. ft. on stock turbo.
Kawasaki Ninja ZX-12R 1200cc's, 190 hp of pure evil on 2 wheels.
95 Jeep Cherokee BDS/hybrid 5" lift, 32x11.5 BFG mt's, welded rear diff, long arms, etc. trail beater.
19psi is offline   Reply With Quote
Old 02-22-10, 07:53 PM   #52
JimsGX
Trader Score: (0)
Quote:
Originally Posted by 19psi View Post
"you won't have high beams, but you won't need them"
Some states require high beams to pass the annual vehicle inspection. So you either need the bi-xenon's, or you'll have to swap out the HID's once each year for standard high/low's to get an inspection sticker.
Jim
JimsGX is offline   Reply With Quote
Old 02-22-10, 08:03 PM   #53
chippern73
Trader Score: (0)
Without starting another thread, How are is it to wire in the HID lights? I thought there was more to it then just plugging them in?
chippern73 is offline   Reply With Quote
Old 02-22-10, 08:33 PM   #54
JimsGX
Trader Score: (0)
Its an easy job. On a scale of 1-10, its a 2... A typical kit comes with a wiring harness that plugs into your existing harness on the drivers side, two high voltage ballasts and one or two relays. Depending on how picky you are, it's a 1 to 2 hour job including beer breaks.
Old 02-22-10, 09:59 PM   #55
sam12345
Trader Score: (1)
where I am at they have inspections every year. Has anyone failed inspections with hid? and has anyone gotten a ticket with HID?
Old 02-23-10, 09:20 AM   #56
Brandicus
Trader Score: (6)
Brandicus's Avatar
Send a message via AIM to Brandicus
Quote:
thanks man, I plan on sanding down the corners to clear and rattle canning them black to match, the whole car will be a repainted a dark color so this is just a preemptive move to match.
also the lense arent recessed on purpose lol, I had to send in my glass lenses to have a mold made of them, so for the time being i cut some peices of pexiglass to fit, so far they have survived many a rainy day so itll do for now.
on topic hid kits are very illegal due to the glare they cause, however if you point them down i dont think youll bother anybody, I ran one for a couple years and i think most cops just think it came stock, like some 90s lux cars.
__________________
Brandicus is offline   Reply With Quote
Old 02-23-10, 10:02 PM   #57
sam12345
Trader Score: (1)
Tonight I was stopped at a light across the street from a guy who had HID's. He either had them adjusted wrong or it was a retrofit. Blinded me till I almost saw spots. If this is what an HID conversion will do I do not want any part of it.
Old 02-23-10, 10:22 PM   #58
PureDrifter
BahHumBug
Trader Score: (10)
PureDrifter's Avatar
PureDrifter
Send a message via AIM to PureDrifter
you got it backwards...
if it was a retrofit it WOULDNT glare.
hid in stock non-hid housing or worse yet, fluted glass housings, will glare to all hell.
__________________
1. Black on Black 1999 LS400 PM-spec
-Maya-Megan-Magnaflow-LSportline-Xenondepot-PPE Engineering-Duce-Platinum VIP-Figs Engineering-R1Concepts-
2. Black 2001 MR2 Spyder -#muchroadster-
3. Black 2004 IS300 -Manaray-HKS-Eibach-Kumho-
4. Ebony Teal 1995 LS400 11-8-06
PureDrifter is offline   Reply With Quote
Old 02-23-10, 10:49 PM   #59
sam12345
Trader Score: (1)
Thats what I meant by retrofit. Putting hid in a stock light meant for halogen. I did not mean adding projectors. That I would do if it wasn't for all the hassle and money
Old 02-23-10, 11:50 PM   #60
PureDrifter
BahHumBug
Trader Score: (10)
PureDrifter
there's a difference between a retrofit (which explicitly involves using projectors/reflectors (rarely) from an OEM HID car) vs. a conversion....
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ls400 seat help? xxmariolxx LS400 0 02-26-14 11:59 PM
New to me 1990 with NO brights? basically LS400 3 08-07-11 01:23 AM
1990 ls400 remote key lexuls400 LS400 3 05-25-11 04:25 PM
1990 ls 400 spiderinlv LS400 4 02-05-11 08:45 AM
Year Differences (1990-1991) BabyBoy068 LS400 2 10-22-08 09:10 PM
Tags
1990, 1992, 1996, 400, automatically, bulbs, head, headlight, headlights, lexis, lexus, light, ls, ls400, projector
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
