Best coilovers for comfort/price...
Old 10-30-14, 07:06 PM
RobertE
RobertE's Avatar
What is the $200.00 difference between the Megan LP & Megan EZ. I know the LP adjusts dampening 32 ways versus EZ's 15 ways but what other difference is there for the difference in price.
Old 10-31-14, 03:47 AM
RugbyDad
RugbyDad's Avatar
Pillow ball upper mounts.
Old 10-31-14, 07:10 AM
Kingsoup
Kingsoup's Avatar
Are pillow Ball mounts needed on a car like the LS with double wishbone suspension? I guess if you lower it a lot, hmmm I should look up if you need camber adjustment on a mild lowering.
32 way vs 16 way I wonder if its just a different system of valving and the same body and cartridge, hmmm.
Old 10-31-14, 01:38 PM
timmy0tool
timmy0tool's Avatar
there is no benefit to running pillow ***** on a double wishbone setup. camber cannot be adjusted via camber plates either.
for mild lowering, camber can be adjusted to stock specs via eccentric bolts on the lower arms connecting to the subframe.
jwynn
Suspension and Brakes
14
01-30-17 10:48 PM
jvah1980
08-06-16 09:25 PM
panda327
23
02-05-15 10:19 AM
melski415
01-09-12 05:34 PM
DRLC6
Suspension
05-04-10 02:03 PM
Quick Reply: Best coilovers for comfort/price...
