How long do LS4 ball joints last?
Old 02-03-10, 02:34 PM
amcdonal86
amcdonal86's Avatar
Default How long do LS4 ball joints last?
I'm about to replace mine at 112k miles and I'm wondering if I should expect them to be bad yet.
If you replaced yours (or checked yours), at what mileage did they start to fail?
Old 02-03-10, 05:43 PM
trukn1
NELOC Mod
trukn1's Avatar
Unless you have other suspension problems, causing them to fail prematurely, they should last a good clip. Normally lowering a car will shorten their life a little as well as having worn bushings, worn out suspension components, etc. The LS is know for eating ball joints b/c it is a very heavy car. What is your car doing, suggesting that you need balljoints? Normally with the lowers, especially in the front, you will feel the car kinda jump to one side when making a hard turn or you will notice a bit of vibratioin thru the steering wheel(although there are MANY causes of vibration). Also a visual inspection of the ball joint itself should yield no leakage in that area or splitting of the rubber boot.
Old 02-03-10, 06:41 PM
amcdonal86
amcdonal86's Avatar
I have this annoying popping from the right front (sometimes the middle front?) that can occur when I get on the brakes, especially at lower speeds and when turning. However, the noise can also occur when I am going straight, provided I am on the brakes.
The car seems to wander on the highway, but I am really not sure whether or not this is just me being crazy or whether it is the car actually wandering. Also, the steering wheel seems to have poor returnability to center after a turn, but again, this might just be my perception. It seems I have to assist the steering wheel back to center heavily after taking a sharp corner at 10-15 mph.
Recently, I have replaced the front swaybar bushings, the front brake pads and shims, the front strut bars, and upper strut mounts. Upon last inspection, upper ball joints were in fine shape. I also recently flushed the powersteering fluid.
Is 112k miles really too early to have lower ball joints go bad?
Old 02-03-10, 08:29 PM
willhickey
willhickey's Avatar
no not at all it depends on the driver and roads..... if it you hit every pothole curb speedbump fast etc. they wont last long at all there is no way to put mileage claims on balljoints and if your boot busts and you get water, dirt, salt in there they definitely arent going to last 112k then not even close
Old 02-03-10, 08:39 PM
LiCelsior
Retired
LiCelsior's Avatar
i changed mine due to my brake upgrade and i dont notice much difference so i guess my old ones were still good.
Old 02-04-10, 06:25 AM
Bradster
Bradster's Avatar
1990 LS400 with 245K miles..Front end all original and still tight...Lexus/Toyota mechanics very impressed
Old 02-04-10, 06:51 AM
amcdonal86
amcdonal86's Avatar
So do my symptoms sound like LBJs?
Old 02-04-10, 07:01 AM
McSwine
McSwine's Avatar
Just replaced mine on my 2000 LS @ 142,000 miles. I replaced mine to stop an annoying "clunking" noise when going over speed bumps, which it did not fix, but it did noticeably tighten up my front end when going over smaller, sharper bumps.
Glad I did it, and a relatively easy fix if you have the right tools.
Old 02-04-10, 08:30 AM
j three
j three's Avatar
I think this also could be the strut rod bushing going bad. I remember the driver front strut rod bushing was trashed on my 91, and when you hit the brakes the tire would move slightly like you were turning and it would also make a clunk. Also if I was going down hill and hit the brakes to maintain speed that thing would shutter like crazy!
Old 02-04-10, 01:01 PM
amcdonal86
amcdonal86's Avatar
Well, I replaced them. The passenger's side one looked okay, if not a little bit loose (no play, just not enough resistance). However, the driver's side one was partially seized, with very limited motion of the joint. I believe this was the source of my noise. I only had a chance to do a short test drive, but I don't believe I heard the popping that I had become accustomed to. I will do a longer drive this evening and see whether or not the problem is truly gone.
Certainly the one ball joint was failing and I am glad I replaced it.
Old 02-05-10, 10:57 AM
amcdonal86
amcdonal86's Avatar
Well, it turns out the noise didn't go away. I don't believe it is brake related, since it can happen even if I'm not on the brakes (and haven't been for a long time).
My main suspect is the lower control arm bolt, which I hear can become less tight than it should be, allowing the lower control arm to shift during driving, causing a loud banging noise. It seems to mostly be an SC issue, though...
Other suspects are the upper control arm bushings. (By the way, is it really necessary to remove the shocks to replace the UCAs? It looks like a pretty simple procedure, otherwise...)
Old 02-05-10, 10:59 AM
willhickey
willhickey's Avatar
I wish you luck bud. Good luck with the fix and when you do figure it out please post it so everybody can learn from your experience.
Old 02-05-10, 11:53 AM
McSwine
McSwine's Avatar
One guy with a '98 (I think) mentioned he fixed his noise by tightening the subframe bolts. I'm about to get new tires and have an alignment done...I'm going to ask the alignment guy to tighten them and see what happens.
Old 02-05-10, 12:12 PM
amcdonal86
amcdonal86's Avatar
Thanks. I definitely will, there's nothing I hate more than finding threads where the OP has the exact same symptoms as me, but never posts a solution or finding...
Old 02-08-10, 09:36 AM
amcdonal86
amcdonal86's Avatar
Well, I'm just following up. I tightened my LCA bolts and now the popping is much louder! This is good news, because I think I've isolated the problem!
I've started a new thread about this:
https://www.clublexus.com/forums/ls4...ml#post5209226
dicer
12
09-08-16 02:32 PM
mafpolo
09-28-15 04:32 PM
DMPesso
Suspension and Brakes
26
04-28-15 06:24 PM
akafixture
12-16-14 09:56 AM
PlotPoint
17
11-22-13 08:24 AM
Quick Reply: How long do LS4 ball joints last?
