Gas mileage...good-bad (The Mother thread)
Old 09-23-03, 10:07 PM
  #106
dan
dan's Avatar
Red face LS 400 mileage
If you guys can't get 22mpg around town and 28mpg on the highway you are living in the wrong hemisphere.My LS has 330 k's on the clock and still knocks off the local hoons.
Old 09-23-03, 10:50 PM
  #107
LexLS
LexLS's Avatar
Dan welcome, wait...Where have you been....I see registered 2002! j/k
Care to shed some insights for us since you have put some serious miles on your LS?
Old 09-24-03, 01:23 AM
  #108
Bj(CA)
Bj(CA)'s Avatar
ok, here it is in a nutshell, if you can afford an ls400, you can afford the gas. if not, get a trecel
i drive my ls hard!!! iam not even worried about gas anymore, lol!!!
bj
Old 09-24-03, 04:52 PM
  #109
dan
dan's Avatar
Hi Earl and Bj,I have had my ls for 18 months.The main reason for the ls was the handling to avoid kangaroos and the pace to outrun Emus .The only replacements I have had to do were Steering rack(2nd hand but can be rebuilt for about $A800) and Air compressor Broken shaft.(bloody hot down here!) Replaced front struts because of a rattle in front end(and 320000K's on the clock) Rattle is still thereand handling is still the same......Just can't break these darlings......All our judgments have been vindicated by the LS being named Car of the Decade and topping most other awards around the globe.I intend to keep mine in concourse condition and sell it back to the Japs in 2020 for twice what I paid for it! Try and do that with a Beema or Merc. Joyful motoring!
Old 09-24-03, 09:32 PM
  #110
persian451
persian451's Avatar
I get about 350-400 miles till the light turns on
Old 09-24-03, 10:39 PM
  #111
LexLS
LexLS's Avatar
Post
I just looked...18.5 gallons is the most I have ever put into a fill-up. The gas light was on. My '91 manual says the gas tank holds 22.5 gallons. That means when the gas light comes on there is still about 4 gallons in the tank.
What's the most gas you've put in the tank on a re-fueling?
Old 09-24-03, 11:09 PM
  #112
persian451
persian451's Avatar
20 gallons.. I know you get scared to push all the way to the last gallon... put i heard its bad to drive to the light.. always pump at the quarter mark because you are gonna get the junk at the bottom fo the fuel tank sucked up if you drive it to the last gallons
Old 09-25-03, 06:29 PM
  #113
dan
dan's Avatar
Default MPG.
Not very scientific Earl. You need to fill your car up and note your mileage or set your trip meter.Then drive as you would normally until you have used at least 3/4 of the tank.Fill up again and note how much fuel is used and how far you have travelled.Divide the Miles by the gallons and you have MPG.To convert Kilo's to miles multiply the first two digits by 6.To convert litres to gallons divide by 4.5(or more exactly 4.54609)This is imperial gallons. This way you are not guessing how much is left in the tank.P.S.For those who believe there is no contamination/water in their tank,I would suggest drain it sometime,burn off the excess fuel ands see how much water is left!
Old 09-25-03, 10:08 PM
  #114
LexLS
LexLS's Avatar
Default Re: MPG.
Scientific enough! My last post was only asking how much gas anyone has ever put in their tank on a fill up. Mr. Persian answered that with 20 gallons and no one has that record beat as of yet. If you can't tell I've changed my views on this gas tank filling issue. You guys have all convinced me to start filling up at 1/4.
I know how to calculate my mileage thank you.
Old 09-25-03, 10:19 PM
  #115
persian451
persian451's Avatar
lets get over this gas mileage issue.. our cars just like fuel fed to them
Old 09-25-03, 11:48 PM
  #116
dan
dan's Avatar
Talking out with the gas and in with the tyres
Good idea persian.What about tyres? How do you rate the Falken st115 and michelenMXV8 ?
Old 09-26-03, 07:23 AM
  #117
persian451
persian451's Avatar
you got me there... that stuff i have no clue about.. go to the tire forum
Old 09-26-03, 08:59 AM
  #118
kamtra
kamtra's Avatar
Default junk in gas tank?
The next time someone who hates you puts sand in your gas tank, you'll be happy that there is a drain at the bottom. However, if you think that there is crap at the bottom of the tank (apparently crap doesn't float) then clean the thing out. It's really easy to take out through the trunk- it's behind the rear seat. The reason you're not supposed to take it to the empty light is so you don't run the fuel pump dry. If anything like dust or flies gets into your tank- remember the tank is not full of water, it's gasoline. It'll break everything down into a nice musch for your fuel filter to eat. Seriously though, when was the last time a bug made it's way down your gas tank pipe?
Old 09-26-03, 12:59 PM
  #119
RA40
Super Moderator
RA40's Avatar
Having killed 4 fuel pumps due to driving below 1/8 tank, I fill the car up right away. Having gone through that, my tank didn't have too much sediment.
It was times like that I wish the fuel pumps were good at pulling as I would have installed an external unit. I dunno which I like more, the external lower gas tank or trunk mounted gas tank. At least if you spill gas, it is contained outside; on a trunk mount, yuck.
The better lesson, don't drive below 1/4.
Old 09-28-03, 07:59 PM
  #120
97LS400
97LS400's Avatar
Default mileage & reserve fuel
I'm surprised nobody has commented on the ACCURACY of our fuel gauges. I have never seen or owned a car with a gauge that reads so accurately before. I know that 100 miles per 1/4 tank (on the gauge) is "21.something" mpg. Since my "normal" is 22-23 mpg (have kept track of every fill up) that means that the reserve light comes on at 400 miles and there is a 100 mile reserve. Average mileage on a road trip is 27-28 mpg. Of course your mileage might be less, I have a steady foot and avoid speeds in excess of 140mph most of the time.
Those of you with low fuel tanks concerns: As a Honda Parts/Service manager for 10 years I can assure you that running down to the reserve light won't hurt anything if your fuel supply/quality is consistent. Adding methanol-laced fuel to a car that has had a steady diet of 100% gasoline can be a problem however.
Many a car was towed into our shop because someone used to getting 100% gasoline got a tank full of 90% gas/10% methanol. What this does is dissolve a different assortment of "stuff" than straight gasoline does... sending it straight down the fuel line to stress the fuel pump and plug the filter.
An unscrupulous shop might replace the fuel pump in that case when all you (normally) need is a new fuel filter.
97 LS400, 22-23 mixed driving to work and 27-28 on road trips.
LOVE THIS CAR!
Quick Reply: Gas mileage...good-bad (The Mother thread)
