Gas mileage...good-bad (The Mother thread) - Page 3 - Club Lexus Forums
Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign In
Register Forgot Password?
Thread Tools Search this Thread
Old 06-21-02, 04:51 AM   #31
Pyrotech
Trader Score: (0)
Default distance
on my 95 LS400 i get an average of 400 miles per tank. most of my driving is on the highway to and from work but i do drive like a bat out of hell most of the time. usually i cruise at about 80 for the 40 mile hike with short bursts of speed of up to 100 or 110 for passing (i get frustrated really easy on the highway with drivers in the left lane). just recently, i drove 120 miles city using a/c and still got just shy of 400 miles for the whole tank.
this last fill up i used sunoco ultra 94 and my yokohama tires have the 29 psi pressure recommended by the dealer. i'm sure that if i had not used the a/c and drove 65ish-70ish i'd have racked up 500 miles on this tank. i had the 60000 mile serve done at 73000 miles when i acquired the car. now i just passed 94000. i actually get better mileage than my friend who has one of those 4cyl neons. but that's not sayin much. lol.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Pyrotech is offline   Reply With Quote
Old 06-21-02, 10:08 PM   #32
rsg
Trader Score: (0)
Wait, doesn't the alternator run just as fast as the RPMs the engine is running at? It doesn't run faster when you turn on the big amps does it? If that's true then the radio, amplifiers etc won't have any affect on the mileage.
rsg is offline   Reply With Quote
Old 06-22-02, 04:29 AM   #33
additude
Trader Score: (0)
Actually,
Due to the physics of magnetic induction (Those principles are used to create a flow of current or "electrons" through a conductor that is passing through a magnetic field) an increase of current TO the load FROM such a device as an alternator will increase the amount of energy required to turn it's armature. The simple physics is that the magnetic fields inside of an alternator are always trying to "Line Up" if you will to the North and South poles of the enclosed magnetic field.
The more current flow through the device the stronger the magnetic fields created and hence the harder it is to separate the natural tendancy of fields to align with pole to pole orientation.
Take two pair of horse shoe magnets for example. One pair is very strong in magnetic flux and the other is weak. Allow the ends of the magnets N & S poles to "Attach" for both magnets, the strong pair together and the weak pair together, then try to pull them apart. The magnets with the stronger flux fields will definately be harder to separate than the weaker magnets.
Consider the magnets with the stronger flux fields comparable to the magnetic fields in your alternator under a heavy load, like turning your bright beam headlights on. The heavier the load, the more current required and the more current required the stronger the magnetic fields will be inside the alternator. It will require more torque from the engine to turn the armature inside of the alternator with the headlights on then it will with just the load of a normal running engine.
Anyway, thats the theory. Turning the alternator armature through the magnetic fields at a higher rate of speed increases the frequency and amount of the total output available to the load. It's the RMS (Root Means Square) output value. So two basic things are at play here, the strength of the magnetic field and frequency with which the conductor passes through that magnetic field.
Now, in a circuit such as a car, when the load requirement exceeds the maxium output of the alternator based on it's rated capacity at a specific frequency, part of the load will be supplied by the battery. Typically an alternator needs about 2,500 RPM to achieve it's rated output. So, when you place a heavy load on the alternator and your car is idling, some of that load may be supplied by the battery until the alternator can handle the entire load.
If your load requirement consistantly exceedes the rated output of the alternator it will slowly and methodically discharge your car battery.
So, if you put a big 'ole honking sound system in your car that's a real juice hog and you don't have an alternator that can handle it your going to have troubles.
Now, why do we use alternators instead of generators?? Another story....some other day.
__________________
If you want something you have never had before;
You are going to have to do something you have never done before.
additude is offline   Reply With Quote
Old 07-05-02, 06:57 PM   #34
GA400
Trader Score: (0)
GA400's Avatar
Post
Guys,
Another update. i have used the engine restore stuff (engine does seem to run quieter and smoother now, even though it was good before), B-12 chemtool fuel injector cleaner (mechanic's recommendation), tires at 40 psi. Road trip from Alpharetta, GA to Folly Beach, SC for the 4th - average mpg has climbed from 17.5 before to 22.5 now (about 80 % freeway at 75-85, rest a mix of city and construction zone stuff). I will check it on the way back home too to verify, but I am very happy with the change. I may still try the Tornado, just for the heck of it.
Thanks for the advice,
rhlight
__________________
GA400
99 GS400 Nav/TEIN CS and EDFC/Borla
GA400 is offline   Reply With Quote
Old 07-07-02, 12:29 AM   #35
rsg
Trader Score: (0)
I heard that the Tornado doesn't do anything, but I installed it in my other car, and I'm not sure if it was just my imagination, but I felt more power (only around redline though). I also installed a K&N air filter at the same time, but that is only supposed to increase 2-3 horsepower. As far as it saving gas, I did not notice a change, but that's not why I bought it in the first place. After I saw the infomercial in which a car had an increase of 20 horsepower, I bought it. Maybe someone here with access to a dyno could test the HP before and after putting it in the car? Might be worthless, but I am not going to take it out of my car.
Old 07-07-02, 12:37 AM   #36
LOTC
VIP 様式
Trader Score: (0)
LOTC's Avatar
Send a message via AIM to LOTC
Quote:
Its not worth the time to dyno that thing.If it really did give a car 20hp everyone would have one in their car and I dont think it gives you better gas mileage either.
There has been tons of threads about this tornado device and its just basically a scam for $$$$$$
__________________
VIP Celsior
LOTC is offline   Reply With Quote
Old 07-07-02, 12:26 PM   #37
herbvdh
Trader Score: (0)
Default Fuel economy
In the city I average 20.5 MPG just did a highway run and I got 25 MPG no speed over 75 we kept an average of 65 MPH I will not complain this better in the city than my 2000 RX300 the highway is about the same. The LS only gets super 93 octane.
herbvdh is offline   Reply With Quote
Old 02-18-03, 04:14 PM   #38
ychachad
Trader Score: (0)
ychachad's Avatar
Default 24 mpg, is that all?
My 1992 LS400 gave me 24 mpg, going consistently at 70 mph. That is poor, I think, considering my 1995 MB S420, which seems twice as big, and three times as heavy, gives me 26 mpg under identical conditions on the same road. Not impressed with LS400. What do you guys get?
__________________
Y. Chachad
2007 Lexus LS460
2002 Subaru Impreza WRX
2015 Toyota Avalon XLE Hybrid
1989 Honda NX250
2002 Kawasaki Vulcan 800
2013 Kawasaki Ninja ZX10R
ychachad is offline   Reply With Quote
Old 02-18-03, 05:24 PM   #39
LOTC
VIP 様式
Trader Score: (0)
LOTC's Avatar
Default Re: 24 mpg, is that all?
Quote:
24 mpg is considered pretty good for the LS. I have seen LS's range from 18-25mpg depending on driving conditions and condition of the car.
As far as the MB S420 being twice as big and 3 times as heavy. Then your MB S420 must be almost 20ft long and 12,000lbs
__________________
VIP Celsior
Old 02-18-03, 05:27 PM   #40
LS400
Club Lexus Editor
Trader Score: (0)
24 MPG going 70 MPH consistent is impressive.
I barely get 20 MPH period.
Might need to re-check your figures.
LS400 is offline   Reply With Quote
Old 02-18-03, 05:55 PM   #41
ychachad
Trader Score: (0)
ychachad's Avatar
Nope, the figures are correct, 70 mph, 24 mpg. Consistent on several occasions. I was joking when I said the MB S420 feels twice as big, and 3 times as heavy, but it certainly is a more massive car, and it consistently gives me better gas mileage than the LS400. The MB is certainly more impressive.
__________________
Y. Chachad
2007 Lexus LS460
1989 Honda NX250
Old 02-18-03, 06:00 PM   #42
LOTC
VIP 様式
Trader Score: (0)
LOTC's Avatar
Well, Im only getting about 17-20 mpg with my large rims, so your lucky. Plus with the gas prices shooting up to the roof :eek:
__________________
VIP Celsior
Old 02-18-03, 06:07 PM   #43
Lvangundy
Guest
Trader Score: ()
Posts: n/a
Wow 24MPG? I've never gotten that even on a 300 mile cruise.
My last tank was about 17MPG.
I've gotten 14 before with the K&N filter (boooo)
Old 02-18-03, 06:43 PM   #44
retrodrive
Search Function Inc.
Trader Score: (0)
retrodrive's Avatar
Send a message via ICQ to retrodrive Send a message via AIM to retrodrive
I used to get 260 without exauhst and i think now I get 300 miles per tank if I am lucky.
__________________
http://www.cureline.net/lex/gfx/other/sig_brakes.jpg
Anything You Need To Know About LEXUS LS400!
Reviews, Audio Applications, Performance Articles, Galleries etc.
.:: LS300T 660rwhp 918rwtq Auto
retrodrive is offline   Reply With Quote
Old 02-18-03, 09:06 PM   #45
IS200 3SGTE
Trader Score: (0)
Send a message via ICQ to IS200 3SGTE
my 2.2L 3SGE corolla got 40MPG on my way to NJ from Canada.
24MPG is pretty good for a 4L V8 and a 3500+LB car. maybe it is because the car is a little old and the engine needs some care.
IS200 3SGTE is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas mileage Titten GS - First Generation 16 12-15-14 05:02 PM
MPG Crappy sprocket GX - First Generation 45 11-27-14 09:03 AM
Horrible gas mileage! djpeakSD GS - Fourth Generation 19 09-08-14 10:17 AM
03 GS 300 14 mpg :-( danyeru GS - First Generation 14 04-08-14 08:00 PM
MPG for a car life alpinefun ES350 and ES300h (2013+) 5 03-12-14 05:46 PM
Tags
00, 1991, 1992, 1995, 1996, 1997, 1998, 2003, 21mpg, 225gallons, 2ngmiles, 350, 400, 450, 470, 8942220010, 92, average, bad, car, cars, change, computer, cost, current, driving, drop, economy, edmonds, efficiency, empty, es, es300, ethanol, exterior, factory, fill, foot, forum, fuel, fuel economy, full, gal, gallon, gallons, gas, gen, generation, high, highway, hs250h, idle, iridium, is09, is300, la, lexas, lexus, light, lightfoot, ls, ls40, ls400, ls430, lx, lx400, milage, mileage, miles, mpg, oil, orignal, pics, real, red, rims, road, series, small, sudden, takes, tank, tips, trip, ucf10, world
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
