Crankshaft sensor
https://www.clublexus.com/forums/ls4...o-power-2.html
Courtesy of LexLS.
http://www.lexls.com/tutorials/engine/timingbelt.html
You can see the harness right there.
Courtesy of LexLS.
When you say no power, you need to be specific. In your last thread, you just said the car had no power. Then several posts later you state that it does turn, but doesn't start.
The sensor is magnetic. If d/c or has trouble in the wiring, the car will fail to start and continue turning regardless of fuel/spark.
