91 ls 400 oil light still on
Old 01-14-10, 08:52 AM
dleadlexus
dleadlexus's Avatar
Default 91 ls 400 oil light still on
my ls oil light stays on and so does my antilock break light is there any way to fix this
Old 01-14-10, 09:29 AM
bacaudio
bacaudio's Avatar
The oil light is on either because your engine is low on oil (I'm sure you have checked) or because the oil pump is bad or it could simply be that the oil sensor has gone bad. Also with the abs light there are sensors for those and if any of the wires have been cut it would stay on or this also could simply be a bad sensor. They are on all wheels so any of them could be the one causing the problem.
Old 01-14-10, 09:40 AM
avalon42
avalon42's Avatar
If you don't have erratic braking, try topping off your brake fluid. If it is full, then it's the sensor on top that failed.
Corralesr
Performance
04-11-19 01:48 PM
hobojoe
16
04-08-08 11:01 PM
1stGS30
GS - 1st Gen (1993-1997)
11-25-07 03:26 PM
Brownja
Performance & Maintenance
05-19-07 10:14 PM
Quick Reply: 91 ls 400 oil light still on
