warning light in instrument cluster!!!
Old 01-05-10, 09:52 AM
93ls40082
93ls40082's Avatar
Default warning light in instrument cluster!!!
Hey guys.. I have a 93 lexus ls400. There is a red circle around which there are some dotted concentric lines in the right lower corner of the instrument cluster. does any one know what this indicates? any help will be appreciated...
Old 01-05-10, 10:05 AM
LiCelsior
Retired
LiCelsior's Avatar
ur owners manual would tell u right away.
Old 01-05-10, 10:06 AM
93ls40082
93ls40082's Avatar
HI.. I bought it from a private owner. they dint have a owners manual. do you have idea where u i can get one?
Old 01-05-10, 10:28 AM
LiCelsior
Retired
LiCelsior's Avatar
u can get a fee one, go to the Great Deals classified section, and look at the top.
Old 01-05-10, 10:46 AM
93ls40082
93ls40082's Avatar
hi,...the owners manual says i have to take it to a dealer. i dont get this.. coz it does nt says something is wrong.take it to a dealer for what? does it mean regular service reminder?
Old 01-05-10, 10:49 AM
91LS400LEX
91LS400LEX's Avatar
Sounds like its your brake lining warning lamp. I know that my old 1985 Mercedes had this light and it looked like that... it signaled worn brake pads.
I am not sure, because my 1991 dont have this light feature.
You can get a free owners manual from Lexus.... www.lexus.com I think.
Old 01-05-10, 10:58 AM
steve2006
steve2006's Avatar
It is the brake pad wear warning light so get all your brake pads checked asap the bad news is the sensor attached to the pads is now probably broken too and they are expensive to replace.
If all the pads check out OK have the sensor wiring checked
Old 01-05-10, 11:24 AM
93ls40082
93ls40082's Avatar
the previous owner told me the brake pads were replaced 2 yrs ago.. the brakes function just fine. will resetting the computer fix the issue?
Old 01-05-10, 12:36 PM
Amskeptic
Amskeptic's Avatar
Originally Posted by 93ls40082
the previous owner told me the break pads were replaced 2 yrs ago.. the breaks function just fine. will resetting the computer fix the issue?
B-R-A-K-E-S as in "to brake" "retard the motion of an object"
Thank-you.
Miss Gosnell (your second grade teacher)
(brake pad sensor $35.00 www.CarPartsToGo.com)
Old 01-05-10, 01:00 PM
93ls40082
93ls40082's Avatar
oooopsiii!!!!
Old 01-05-10, 02:06 PM
91LS400LEX
91LS400LEX's Avatar
Well, two years may be OK if the car has not been driven much, but brakes mostly are a mileage thing. Some last longer than others, depending on driving habits, brand of pads and type of car.
The brakes on my LS400 have were installed at 200K and it has 225K now. No squeaking or scrubbing, but I am getting some feedback through the steering wheel during braking... I guess the rotors need to be turned.
RandomHero
18
08-28-08 03:19 PM
ryanSC300lover
07-23-08 06:41 PM
agood1
08-26-07 04:44 PM
LexCarPC
01-06-05 03:55 PM
Lil4cyl
RX - 1st Gen (1999-2003)
10-01-02 01:43 AM
Quick Reply: warning light in instrument cluster!!!
