Old 12-16-14, 11:57 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
Soft Brake Pedal/Goes to Floor
Old 12-30-09, 05:49 PM
dillon81
dillon81's Avatar
Default Soft Brake Pedal/Goes to Floor
Hey Guys,
I have a 1999 LS 400 with only 60K miles and the brake pedal goes all the way to the floor as you keep applying pressure. I have brand new OEM pads on the car. The cars seems to stop fine but you just don't have that positive feel. I have been told that it can be a wore out master cylinder. Any other members with a similar problem on there 1998-2000 LS 400? Any input would be greatly appreciated.
Thanks,
Dillon
Old 12-30-09, 06:03 PM
trukn1
NELOC Mod
trukn1's Avatar
Possible air in the lines. Did you bleed the brakes? Low brake fluid? Start checking the obvious things first before you start to throw money at a master cylinder.
Old 12-30-09, 06:10 PM
dillon81
dillon81's Avatar
TRUKN1,
Thanks for the reply. I did take the car to the dealer and they checked for air in the lines but didn't find anything.
Old 12-30-09, 06:17 PM
91LS400LEX
91LS400LEX's Avatar
Sounds like the master cylinder is failing. I had a car do this (not a Lexus) and it was the master cylinder.
One thing I can say is that I have never had a brake problem on either of my Lexus (1990 and 1991).
Old 12-30-09, 06:41 PM
trukn1
NELOC Mod
trukn1's Avatar
Originally Posted by dillon81
TRUKN1,
HUH?? You took the car to a dealer, with the brake pedal hitting the floor, and they didn't find anything wrong?? 2 things,,,
1. Demand your money back, since there is obviously SOMETHING wrong with the braking system.
2. NEVER go back there again.
That is ridiculous. As long as you have no air in the system, and the fluid is full, then it may very well be your master cylinder. I would get a second opinion from a reputable mechanic.
Old 12-30-09, 06:47 PM
dillon81
dillon81's Avatar
TRUKN1,
I agree with you 100%. I don't care what kind of car you have, the pedal should never go to the floor. They said they did emergency stops with the car and the car stopped fine. However, the pedal should still not go to the floor as you keep applying pressure. As far as money, they never charged me anything since they didn't do anything to the car. And YES, I don't go to that dealer anymore.
Old 12-30-09, 06:52 PM
JimsGX
JimsGX's Avatar
dillon81,
If you don't have a lot of experience performing mechanical repairs, working on a car's brake system isn't a good place to start. I'd find a good independent mechanic in your area and have them take a look at it.
Old 12-30-09, 08:25 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
brake fluid is cheap. even GOOD brake fluid is reaonably priced. a master cylinder is easily a couple hundred dollars USED. go flush your brakes properly (or have it done) including the ABS block, THEN decide if you need a new BMC.
Old 12-30-09, 11:14 PM
skperformance
skperformance's Avatar
leaking piston seals also cause the same issue, I changed mine and its all resolved with my pedal touching the floor.
Old 01-27-12, 04:14 PM
celsiorlee
celsiorlee's Avatar
hey dillon81 i got a 1999 ls400 that is doing the same thing i bled the fluids and it makes a complete stop, but the pedal goes down to the floor when adding pressure to the pedal. did you ever resolve your problem?
Old 02-03-12, 07:42 AM
chicov8
chicov8's Avatar
celsiorlee did the bleednig make any difrence?
i do have same problem with my 02 gs430
did you try to pump brake pedal 10-20 times? when do that i got all warning lights brake, abs,vsc,vsc off and they disapear in a second or two ifter i stop pumping
Old 02-19-12, 06:38 PM
anesthesia
anesthesia's Avatar
Any follow up on this? My 99 ls400 brake pedal is not as firm like before when braking, ithe pedal goes down further before stopping, wonder if changing brake fluid will help, my pads still have at least 50% left.
Old 02-19-12, 08:28 PM
RA40
RA40's Avatar
Barring obvious leaks in the lines and at the calipers, the first suggestion would be to change brake fluid and check for proper fill levels. Then check the vacuum lines leading to the brake booster, ABS, trac...
Old 08-15-13, 03:57 PM
BlkonBlk96
BlkonBlk96's Avatar
Default Soft brake pedal and makes air releasing sound when applied
I'm in the same boat. Replaced brake booster, master cylinder, flushed brake fluid. New fluid and bleed brakes, still same problem! I push pedal to the floor and get an air release sound. I'm at the end of my rope. Any suggestions?
Shinetrone
04-19-18 07:33 PM
Tallmadge
04-29-17 12:19 PM
89supra884
Suspension and Brakes
10-05-12 02:32 PM
Lexus082
06-21-11 05:39 PM
Lexs400
10-09-03 10:14 AM
Quick Reply: Soft Brake Pedal/Goes to Floor
