UCF20 LS400 Antennas (95-97)
Old 08-14-13, 02:45 PM
Gonads
Gonads's Avatar
Default UCF20 LS400 Antennas (95-97)
Why are they so damn long? Do they sell a kit that deletes it or an antenna that is shorter?
Old 08-14-13, 03:38 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
upgrade to a '98-00. Problem solved!
Old 08-14-13, 10:07 PM
Gonads
Gonads's Avatar
Hahaha!
I guess there isn't an option other than to upgrade to 98-00. lol
Old 08-14-13, 10:45 PM
Dranom
Dranom's Avatar
shave it then repaint
Old 08-15-13, 10:24 AM
RA40
Super Moderator
RA40's Avatar
Those flexible rubber things.
I'm with Dranom if you have the $. The 1980 Celica had an in-glass antenna. Why Toyota goes back-forth on radio antennas is
Old 08-15-13, 10:35 AM
Gonads
Gonads's Avatar
Serious...Hm..I still listen to AM radio at times so I need the antenna, but was hoping for something shorter. Oh well....at least I can't see it when I drive. lol
Old 08-15-13, 12:02 PM
Dranom
Dranom's Avatar
We just bolted the antenna wire to the body of the car when a buddy of mine shave his atenna
Old 08-15-13, 12:06 PM
Gonads
Gonads's Avatar
That is a great idea! Does it mess with reception?
Old 08-15-13, 12:35 PM
Dranom
Dranom's Avatar
When I went for a ride the radio was fine
Old 08-15-13, 01:06 PM
TaffyK20si
TaffyK20si's Avatar
I think the previous owner disengaged mine so it's always down. It still gets good reception while down with my aftermarket stereo.
Old 08-15-13, 03:55 PM
Eskil
Eskil's Avatar
The little while that I drove mine. The antenna made a real loud noise, like if the motor was working to push it out but I guess the antenna is stuck in place. Is there a fuse to turn that off or do I have to deal with it? Thanks again I have a 95 LS400
Old 08-15-13, 04:17 PM
deanshark
deanshark's Avatar
Probably stripped some teeth or snapped the plastic which extends the mast. Very common problem with the stock ones. There should be a plug right on the bottom of the antenna assembly in the trunk. Mine is broke, I just pull it up by hand. (old school)
E36M3
505
03-08-21 01:19 AM
bhdan
04-27-18 12:32 PM
Finn
01-12-14 11:57 AM
boxcarfan
GS - 1st Gen (1993-1997)
08-19-10 09:51 AM
jbreezy27
11-02-09 06:30 AM
Quick Reply: UCF20 LS400 Antennas (95-97)
