first gen fog light problem?!
Old 12-28-09, 12:58 PM
jcp2000
jcp2000's Avatar
Default first gen fog light problem?!
hi all new to the ls family had my first gen since november when i bought it the left foglight was out. I assumed that it was only the bulb so i went to replace it and when i turned them on both where out! aha i dont get it the plug for the left fog (the one that was out) is pretty dirty kinda looks burned imo. What could have made both lights go down? its just odd to me how the right fog was working fine and then when i go to replace the left one both go out aha
Old 12-28-09, 02:20 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
did you check the fuses....?
Old 12-28-09, 02:44 PM
jcp2000
jcp2000's Avatar
no but i am going to if its not the fuse what else could it be!? wiring!?
Old 12-28-09, 07:19 PM
PureDrifter
BahHumBug
check the fuses first, no use in speculating....
Old 12-28-09, 07:40 PM
trukn1
NELOC Mod
trukn1's Avatar
Check that plug carefully. Sounds like you may have an exposed wire somewhere, since you said it looks kind of burned, touching bare metal and as a result you blew a fuse. The fuse for the fogs is located in the fuse box under the steering wheel.
Old 12-29-09, 10:58 AM
jcp2000
jcp2000's Avatar
checked the fuse its fine going to pull the fogs again to check the wiring. the last time i looked i dont remember seeing a lose wire
frotiss
05-16-16 03:42 PM
JH48
02-13-12 07:24 PM
rs/ss
07-15-09 09:14 PM
Maxx941
10-10-08 09:59 AM
Quick Reply: first gen fog light problem?!
