seat motor fuse
Old 12-23-09, 09:54 AM
Lexs400
Lexs400's Avatar
Default seat motor fuse
90 LS, wanted to know if there's a fuse I can pull to disable the motor for the driver's seat to run. or maybe if there's a wire connector within easy reach that I can simply pull to disable the seat motor from running... ? I want the rest of the car electronics to be intact. just want to keep the seat from being adjusted.
thanks.
Old 12-23-09, 11:30 AM
Thermactor
Thermactor's Avatar
Undo the four 14mm bolts that hold the seat to the body, push the seat so that it leans on the rear seats, and undo the electrical connector that goes to the body.
Old 12-23-09, 12:11 PM
Lexs400
Lexs400's Avatar
without unbolting is there a fuse etc that i can simply pull ?
Old 12-23-09, 06:38 PM
Thermactor
Thermactor's Avatar
It would in all likelihood disable both power seats, so this is the easy solution. If you really want to get creative you could rig up a switch that cuts the ground connection to the drivers side underseat ECU, thereby immobilizing the seat. However, that also requires.... unbolting the seat, a task that takes all of about one and a half minutes. Your move, friend.
Champstar
07-22-22 10:11 AM
midwest2
07-19-21 04:13 AM
fsanford
08-28-17 07:48 AM
DarkknessD
05-14-13 09:19 AM
nate579
SC- 1st Gen (1992-2000)
15
11-17-10 03:37 PM
Quick Reply: seat motor fuse
