Pulls to left while braking..
Old 12-19-09, 11:29 PM
toxictv
toxictv's Avatar
Default Pulls to left while braking..
'91 pulls hard to left while braking...but it will sometimes 'go away' if I hit the brakes hard two or three times in a row, and start braking normally til I turn the car off.
Also, some times when braking, and it's pulling, the brake pedal will 'step down' and then it will stop pulling til I turn the car off.
Combination stuck caliper/master cylinder?
Old 12-20-09, 12:05 AM
JimsGX
JimsGX's Avatar
Maybe a bad caliper but I'd check the sliders on the front calipers first. They might be binding up. They should move in and out freely. You can take them out, clean them up and lubricate them. You should only use a silicone paste lubricant on them. If you try and put a regular grease on them, you run the chance of the grease swelling up the small rubber bushings on the ends of the sliders and then they won't slide at all. One product that's sold at Autozone in small packets called Sil-Glyde will work okay.
Old 12-20-09, 12:12 AM
toxictv
toxictv's Avatar
Thanks, I'll try that =)
Old 12-20-09, 12:18 AM
edtbjon
edtbjon's Avatar
Most probably a bad front caliper. Either have it out and overhaul it or get a new or used one.
//Björn
(Seems like Jim hit the submit button a few minutes before me... )
Old 12-21-09, 03:29 PM
toxictv
toxictv's Avatar
Replaced the front caliper..Noticed after the install that I had forgotten to swap out the old hardware for the new (sliders, rubber boots, washers, etc).
Still pulling to the left. Guess I'll swap out the sliders and see if that fixes it.
Old 12-21-09, 03:35 PM
toxictv
toxictv's Avatar
As a side note, I had new tires put on the car last week. While removing the tire I found out that one of the lugs was cross-threaded..
I broke it off by hand. Am I a badass or is that typical?
(please let me have the credit..)
Old 12-22-09, 03:24 AM
Do.Man
Do.Man's Avatar
could be a loose bolt in one of the rear wishbone thingy.
Old 12-22-09, 06:32 AM
python
python's Avatar
a pull while braking is more than likely a suspension problem,unless one of the calipers is completely stuck and wont move..do man means the rear trailing arm bushing,that will cause the car's body to shift,not pull. if u brake and take ur hands off the wheel does the car actually change lanes?
Old 12-22-09, 06:40 AM
JimsGX
JimsGX's Avatar
I'm thinking lower control arm bushings...
Old 12-22-09, 10:11 AM
toxictv
toxictv's Avatar
Yeah it pulls hard enough to jerk me in to another lane.
It's weird though. If I hit the brakes hard four or five times after starting the car it will brake normal til the next time I shut the car off. If I don't hit the brakes hard it will pull, but eventually the brake pedal will 'step' down a little and it'll brake normal from there on out.
Slides, brake line maybe? Going to swap out the slides this evening.
Old 12-22-09, 10:29 AM
JimsGX
JimsGX's Avatar
I know first hand that those slides can cause problems if they're frozen or not moving freely. What your describing as far as the brake pedal, I experienced before re-doing all of my slider pins / bushes.
Old 12-22-09, 10:40 AM
toxictv
toxictv's Avatar
I'll report back once i swap em out this evenin.
Old 12-22-09, 03:51 PM
toxictv
toxictv's Avatar
Well, I replaced the slides, bushings, and brake pad clips.
Still the exact same problem. Could it be the rubber brake line from the caliper to the wheel well? My mechanic friend seems to think that might be it.
Old 12-22-09, 04:32 PM
JimsGX
JimsGX's Avatar
Did you have any trouble bleeding the new right front caliper when you installed it? Have you tried bleeding all four corners?
Old 12-22-09, 04:43 PM
toxictv
toxictv's Avatar
Left front caliper =D
No, it bled off fine, and I have not bled off all four. Brakes seem firm. Odd that it's doing the same thing still..
I'm going to just deal with it for now, then order a braided brake line kit on the 30th and install it when it comes in, since I've been wanting to do that anyways.
Quick Reply: Pulls to left while braking..
