It's in for winter :)
Old 12-12-09, 10:05 PM
renato902
renato902's Avatar
Default It's in for winter :)
Just put in my 95 LS in for winter earlier today. I used an oil stabilizer and a fuel stabilizer and let it run for about 1 hour before i put it in. Seeing that it's not stored in my house (appartment), I won't be able to visit it during its stay. I also disconnected the battery. When it comes out in spring, I'm planning to fix my rear quarter panel rust, slam it on Megans, and get a decent set of VIP style rims. That's gonna fetch easily around $5,000. Everyone from in and around Montreal knows how freakin' harsh our winters can be, the Lexus doesn't deserve that treatment. I have a winter beater, my Suzuki Esteem Wagon 1.8 with Vredestein ArcTrac's (studded) and it just doesn't get stuck Basically, the reason why I'm writing this is to find out what I could've done to store it in a more proper fashion next year. Any ideas?
Old 12-12-09, 10:41 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
did you check the antifreeze?
Old 12-13-09, 06:42 PM
renato902
renato902's Avatar
No, I didn't check the antifreeze. I'm not sure as to why I would need to check it, can you explain? It's also worth mentioning that the car is in a heated garage.
Old 12-14-09, 12:41 AM
PureDrifter
BahHumBug
because if it was outside it would make a pretty big difference...
Old 12-14-09, 03:30 PM
renato902
renato902's Avatar
I see, thanks for the info Pure Do know where I can get some VIP style rims in Canada.. i.e.: AME Shallen LXs, Work Eurolines.. ? If you know of RBWheels.com, can they be trusted?
Old 12-14-09, 09:35 PM
Thermactor
Thermactor's Avatar
Don't tell me that...
Old 12-14-09, 09:43 PM
renato902
renato902's Avatar
Oh man, hurry up and check it out
Old 12-15-09, 07:10 PM
Thermactor
Thermactor's Avatar
Well, the car's been sitting in 10 degree F weather with an unknown coolant/water mix, and I just checked it - the block isn't cracked
So when the weather gets above freezing I'm going to drain out the rad and put a proper antifreeze mix in.
Old 12-15-09, 08:48 PM
renato902
renato902's Avatar
Yup make sure you do that man.. wouldn't want any bad surprises in the spring
Old 12-16-09, 09:41 PM
Thermactor
Thermactor's Avatar
Safe! I drained the old stuff out. Although the coolant mixture was pretty low, maybe about 25 percent, it still didn't freeze on me. I then filled it up with distilled water and ran it with the heater on and the thermostat removed, and drained that. Then I repeated the process... and drained that! Then I filled it up with a jug of Prestone extended life, warmed up the car, and shut her down. Ready for winter.
Old 12-17-09, 01:58 PM
renato902
renato902's Avatar
Glad that's out of the way for you Thermactor, I wouldn't have wanted to see a "My LS is dead" post in the spring
P.S.: It looks like we're having a "who can have the most thumb emoticons in one post" battle
ArmyofOne
Maintenance
02-25-16 07:02 PM
abobiznow
10-16-07 07:08 PM
Will400
SC- 1st Gen (1992-2000)
12-14-05 11:14 AM
BuyERTS
11-06-03 03:55 PM
Quick Reply: It's in for winter :)
