Coolant leak at fire wall>?
Old 05-05-02, 09:45 AM
willy431@aol
willy431@aol's Avatar
Default Coolant leak at fire wall>?
I heard a vibration/noise coming from under the dash of my 93 ls400 when the fan motor was on. Doesn't matter if the fan is on recirc or fresh air---or where it is directed. Popped the hood and there is a sensor of some sort on the firewall with a redish coolant hardened up on it--looks almost like battery acid. I tried to accuate the cable attached to the valve manually with no luck. What is this valve/sensor called?
I assume this is the vavle to switch from the recirc to fresh as there is a heater hose in and one out going to the heater core.
thanks for any hints
mark
Old 05-06-02, 11:41 AM
hyperopt
hyperopt's Avatar
Sound like a leaky heater valve. If you want to know if the actuator/valve is still movable, try setting the temperature to maximum & minimum.
93LexSc400
Performance & Maintenance
14
04-22-20 04:57 PM
IS_Sunny
12-16-13 12:09 PM
lowKut
08-28-09 11:51 AM
ecstaticSC
12
07-14-06 04:50 AM
Quick Reply: Coolant leak at fire wall>?
